Fuel Pump, How to remove/reinstall |
mzapisek |
Mar 21 2023, 07:59 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
My 73 1.7 has the fuel pump in the original location under the battery tray. I just finished reinstalling the engine and the pump is now leaking from what appears to be a bad O-ring from the research I have done. My pump is mounted with what I assume is the original thru body hardware. I was able to reach up and behind to reinstall the pump while the engine was out. There is no access now that the engine is back in. What am I missing here? I would think a service item like a fuel pump wouldn't require the engine to be removed. Thanks.
Geezer914 |
Mar 21 2023, 10:29 AM
Geezer914 Group: Members Posts: 1,418 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Also replace the plastic fuel lines with stainless ones if you have not done that already.
Lo-Fi Version | Time is now: 18th May 2024 - 12:51 PM |
