Fuel Pump, How to remove/reinstall |
mzapisek |
Mar 21 2023, 07:59 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
My 73 1.7 has the fuel pump in the original location under the battery tray. I just finished reinstalling the engine and the pump is now leaking from what appears to be a bad O-ring from the research I have done. My pump is mounted with what I assume is the original thru body hardware. I was able to reach up and behind to reinstall the pump while the engine was out. There is no access now that the engine is back in. What am I missing here? I would think a service item like a fuel pump wouldn't require the engine to be removed. Thanks.
mzapisek |
Mar 21 2023, 11:29 AM
Ok. Got old fuel pump out and realized i was confused about the attachment. It was the hardware that held the battery tray that needed to be accessed from behind. So access isnt an issue. Ordered a new pump (bosch unit) and will decide whether to go firewall or up front. Anyone install the new pump in the original location? I have never had a hot start problem.
windforfun |
Mar 21 2023, 12:00 PM
Senior Member Group: Members Posts: 1,790 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Ok. Got old fuel pump out and realized i was confused about the attachment. It was the hardware that held the battery tray that needed to be accessed from behind. So access isnt an issue. Ordered a new pump (bosch unit) and will decide whether to go firewall or up front. Anyone install the new pump in the original location? I have never had a hot start problem. I have with no problems whatsoever. What battery tray hardware? (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 12:50 PM |
