Fuel Pump, How to remove/reinstall |
mzapisek |
Mar 21 2023, 07:59 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
My 73 1.7 has the fuel pump in the original location under the battery tray. I just finished reinstalling the engine and the pump is now leaking from what appears to be a bad O-ring from the research I have done. My pump is mounted with what I assume is the original thru body hardware. I was able to reach up and behind to reinstall the pump while the engine was out. There is no access now that the engine is back in. What am I missing here? I would think a service item like a fuel pump wouldn't require the engine to be removed. Thanks.
brubou |
Mar 21 2023, 12:38 PM
Bruce Bouchard Group: Members Posts: 92 Joined: 29-February 16 From: West Bradford, PA Member No.: 19,716 Region Association: MidAtlantic Region |
but the battery tray and support are welded in... can you post a pick of your battery holding set up?
Lo-Fi Version | Time is now: 25th May 2024 - 10:09 AM |
