Transmission Output Shaft Seal |
DBF |
Mar 21 2023, 05:07 PM
Member Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I am replacing the transmission output shaft seal and the Haynes manual states to lube with transmission lube. That still the generally accepted procedure?
mgphoto |
Mar 21 2023, 05:57 PM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
930cabman |
Mar 22 2023, 04:59 AM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I am replacing the transmission output shaft seal and the Haynes manual states to lube with transmission lube. That still the generally accepted procedure? I use white grease for the lip of the seal, dry for the seating area. (IMG:style_emoticons/default/agree.gif) |
Dr Evil |
Mar 23 2023, 02:29 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I use some high pressure grease on outside, light coat, and then dry on inner mating surface.
Lo-Fi Version | Time is now: 3rd May 2024 - 03:48 PM |
