Carbs versus FI, I can buy some carbs and stuff but can I buy FI? |
Type 47 |
Mar 22 2023, 05:06 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Can you just buy a FI setup? Or do you have to resurrect your 50 system that has been in a box for forty years and you know something is wrong with it?
gnomefabtech |
Mar 22 2023, 09:26 PM
Member Group: Members Posts: 106 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Any modern aftermarket ECU will be leaps and bounds better than the laptop sized ecu in our cars. A megasquirt or whatever will run great using the stock D Jet hardware with the addition of modern sensors. I haven't done this yet but I think a simple setup with just throttle position, manifold vacuum, engine temp, and ignition map would make for a D-Jet looking engine that would run really well. Not exactly sure how to get a crank trigger wheel on there though.
Lo-Fi Version | Time is now: 17th May 2024 - 07:36 PM |
