Carbs versus FI, I can buy some carbs and stuff but can I buy FI? |
Type 47 |
Mar 22 2023, 05:06 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Can you just buy a FI setup? Or do you have to resurrect your 50 system that has been in a box for forty years and you know something is wrong with it?
gnomefabtech |
Mar 22 2023, 09:26 PM
Member Group: Members Posts: 106 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Any modern aftermarket ECU will be leaps and bounds better than the laptop sized ecu in our cars. A megasquirt or whatever will run great using the stock D Jet hardware with the addition of modern sensors. I haven't done this yet but I think a simple setup with just throttle position, manifold vacuum, engine temp, and ignition map would make for a D-Jet looking engine that would run really well. Not exactly sure how to get a crank trigger wheel on there though.
GregAmy |
Mar 23 2023, 05:58 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
A megasquirt or whatever will run great using the stock D Jet hardware with the addition of modern sensors. I haven't done this yet... I have...see my sig... (IMG:style_emoticons/default/wink.gif) Prego, it's in there...and you can do it too. - GA |
gnomefabtech |
Mar 23 2023, 09:29 AM
[quote name='gnomefabtech' post='3067062' date='Mar 22 2023, 10:26 PM']
A megasquirt or whatever will run great using the stock D Jet hardware with the addition of modern sensors. I haven't done this yet...[/quote] I have...see my sig... (IMG:style_emoticons/default/wink.gif) Prego, it's in there...and you can do it too. - GA [/quote] That's a great setup! I'm sure there are significant power and economy gains to be had from just being able to tune accurately. Plus less smog. Win win win! On another note, it's annoying how expensive throttle bodies are for our cars once they wear out so after a bit of poking around I found that the TB from a 04 Chevy Aveo is the same diameter and has a TPS already. Might work with an adaptor plate. It also has an internal idle port and valve. https://www.ebay.com/itm/284111221789?chn=p...16c0435d2fa1cb8 |
Lo-Fi Version | Time is now: 17th May 2024 - 07:06 PM |
