Carbs versus FI, I can buy some carbs and stuff but can I buy FI? |
Type 47 |
Mar 22 2023, 05:06 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Can you just buy a FI setup? Or do you have to resurrect your 50 system that has been in a box for forty years and you know something is wrong with it?
partsguy22 |
Mar 23 2023, 08:41 AM
Enabler of bad ideas Group: Members Posts: 19 Joined: 8-November 17 From: FT Worth, Tx Member No.: 21,587 Region Association: None |
Clay Said I should mention our efforts towards this.
We have been working on a 914 version of our Carb to EFI kits for 356s We recently did a customers 74 2L and it was a very easy adaptation and will soon be offered as a kit along side of the 356 and 912 kits we currently have. The kit used a MicroSquirt ECU ,Dual 40mm Weber IDF pattern throttle bodies and a hall effect distributor, it retains the stock fuel pump and regulator and integrates into the original relay board for both power and fuel pump control On an otherwise stock 2.0 with a mild cam (web 107i) it ended up making 107whp @5200/112wtq@4250 or 121hp and 126tq corrected flywheel with great drivability Pics to follow if your interested |
gnomefabtech |
Mar 23 2023, 11:55 AM
Member Group: Members Posts: 106 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Clay Said I should mention our efforts towards this. We have been working on a 914 version of our Carb to EFI kits for 356s We recently did a customers 74 2L and it was a very easy adaptation and will soon be offered as a kit along side of the 356 and 912 kits we currently have. The kit used a MicroSquirt ECU ,Dual 40mm Weber IDF pattern throttle bodies and a hall effect distributor, it retains the stock fuel pump and regulator and integrates into the original relay board for both power and fuel pump control On an otherwise stock 2.0 with a mild cam (web 107i) it ended up making 107whp @5200/112wtq@4250 or 121hp and 126tq corrected flywheel with great drivability Pics to follow if your interested So you are not using a crank trigger wheel? Where does the Hall effect distributor come from? Or is it custom made by you? |
Lo-Fi Version | Time is now: 17th May 2024 - 07:17 PM |
