Carbs versus FI, I can buy some carbs and stuff but can I buy FI? |
Type 47 |
Mar 22 2023, 05:06 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Can you just buy a FI setup? Or do you have to resurrect your 50 system that has been in a box for forty years and you know something is wrong with it?
partsguy22 |
Mar 23 2023, 08:41 AM
Enabler of bad ideas Group: Members Posts: 19 Joined: 8-November 17 From: FT Worth, Tx Member No.: 21,587 Region Association: None |
Clay Said I should mention our efforts towards this.
We have been working on a 914 version of our Carb to EFI kits for 356s We recently did a customers 74 2L and it was a very easy adaptation and will soon be offered as a kit along side of the 356 and 912 kits we currently have. The kit used a MicroSquirt ECU ,Dual 40mm Weber IDF pattern throttle bodies and a hall effect distributor, it retains the stock fuel pump and regulator and integrates into the original relay board for both power and fuel pump control On an otherwise stock 2.0 with a mild cam (web 107i) it ended up making 107whp @5200/112wtq@4250 or 121hp and 126tq corrected flywheel with great drivability Pics to follow if your interested |
NARP74 |
Mar 23 2023, 09:57 AM
Senior Member Group: Members Posts: 1,065 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Clay Said I should mention our efforts towards this. We have been working on a 914 version of our Carb to EFI kits for 356s We recently did a customers 74 2L and it was a very easy adaptation and will soon be offered as a kit along side of the 356 and 912 kits we currently have. The kit used a MicroSquirt ECU ,Dual 40mm Weber IDF pattern throttle bodies and a hall effect distributor, it retains the stock fuel pump and regulator and integrates into the original relay board for both power and fuel pump control On an otherwise stock 2.0 with a mild cam (web 107i) it ended up making 107whp @5200/112wtq@4250 or 121hp and 126tq corrected flywheel with great drivability Pics to follow if your interested Very interested. I don't know who you are. What company is doing this? Pics please |
ClayPerrine |
Mar 23 2023, 12:01 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Clay Said I should mention our efforts towards this. We have been working on a 914 version of our Carb to EFI kits for 356s We recently did a customers 74 2L and it was a very easy adaptation and will soon be offered as a kit along side of the 356 and 912 kits we currently have. The kit used a MicroSquirt ECU ,Dual 40mm Weber IDF pattern throttle bodies and a hall effect distributor, it retains the stock fuel pump and regulator and integrates into the original relay board for both power and fuel pump control On an otherwise stock 2.0 with a mild cam (web 107i) it ended up making 107whp @5200/112wtq@4250 or 121hp and 126tq corrected flywheel with great drivability Pics to follow if your interested Very interested. I don't know who you are. What company is doing this? Pics please (IMG:http://www.914world.com/bbs2/uploads_offsite/allzim.com-1143-1679594492.1.png) Zim's Autotechnik. Https://www.allzim.com Partsguy22 is Aaron, the parts manager at Zims. He helped me with the machine work for the 4.0, and I have seen, and driven the their 356 with FI, and have seen the 914 with fuel injection. The system is simple, and fairly bulletproof. It should be a bolt on system with no mods required. Granted, to get the BEST horsepower, you would need to take it to a dyno, but as is, it bolts on and runs. Here's a link to the fuel injection kit for the 356. https://store.allzim.com/356-parts/efi-conv...ersion-faq.html I don't think the 914 FI is on the website yet. Aaron @partsguy22 will have to post pictures. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:30 PM |
