Carbs versus FI, I can buy some carbs and stuff but can I buy FI? |
Type 47 |
Mar 22 2023, 05:06 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Can you just buy a FI setup? Or do you have to resurrect your 50 system that has been in a box for forty years and you know something is wrong with it?
Superhawk996 |
Mar 22 2023, 07:47 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
There is a lot to learn if you’ve never done it before - but you can learn it and the guys here want to help and want to see you succeed.
If this is your first rodeo (sounds like it is) you might want to just hit pause for a day or two. Spend a few days on YouTube and learn more about IDFs and how they work and get two or three perspectives on tuning them. CB Performance also has some good basic setup advice on their site. The main thing is being willing to put in the time to do the iterative tweaking. The first time I did it, it was awful. But once you learn how to make small changes and listen to how the engine responds, it just gets easier and easier and you’ll be proficient before you know it. |
Type 47 |
Mar 23 2023, 05:48 PM
There is a lot to learn if you’ve never done it before - but you can learn it and the guys here want to help and want to see you succeed. If this is your first rodeo (sounds like it is) you might want to just hit pause for a day or two. Spend a few days on YouTube and learn more about IDFs and how they work and get two or three perspectives on tuning them. CB Performance also has some good basic setup advice on their site. The main thing is being willing to put in the time to do the iterative tweaking. The first time I did it, it was awful. But once you learn how to make small changes and listen to how the engine responds, it just gets easier and easier and you’ll be proficient before you know it. We are hitting pause for a few days, good advise. while i've owned 7 914's since 77' this is the 1st one i've completely disassembled (except for the engine/trans) and reassembled. Now that all the ignition stuff got pulled off and messed with I got thrown in the deep end, so tuning is fairly new other than adjusting valves, changing plugs, etc. |
Superhawk996 |
Mar 23 2023, 08:27 PM
We are hitting pause for a few days, good advise. Good call. Here’s something to keep in mind with Webers and Dells of the IDF variety. About 70-80% of your light load, and light throttle cruising occurs on the idle circuit and the off idle transition ports at low throttle angles. It’s sort of crazy to contemplate but you can actually drive pretty decently (relatively speaking) with the main jets and the main emulsion tubes removed. (IMG:style_emoticons/default/new_shocked.gif) seriously! Take the time to understand the idle circuit and to tune it properly. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:01 PM |
