Gas Tank Line Seals, Seals for the two hardlines out of tank |
SteveL |
Mar 23 2023, 12:49 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
Hey all,
I have been fighting an engine dying issue for a while, and am at the step of replacing the fuel sock in the tank and cleaning the tank. I have the tank drained and removed. The tank is awesome. The sock might have had enough crap on it to cause the issue, we'll see. Anyway - 2 lines on bottom of tank, supply with sock and return. I ordered the sock a while back (I think from 914Rubber?) and it came with a copper washer the same as the larger one in the pic. The return line also had a gasket, but it is a fiber washer, not copper. Looking for that gasket, I saw on the AA site that they have a large and small fuel tank seal listed, so I ordered a set thinking it would have me covered. So, the smaller copper washer from AA appears to be the right size for both lines. But if that is the case, why did the sock come the larger washer? Which is right for each? I want to be damn sure this is right, as reinstalling and filling the tank is a crappy way to find out it leaks. Thanks! |
SteveL |
May 5 2023, 06:42 AM
I installed exactly as in the diagrams above- metal sealing washers only - and no leaks.
copilot |
May 6 2023, 12:10 PM
Newbie Group: Members Posts: 7 Joined: 22-July 06 From: Canada Member No.: 6,486 |
I installed exactly as in the diagrams above- metal sealing washers only - and no leaks. Hey Steve. I have a 1975, so I ordered the small copper seals from AA. They have a 10mm id and fit really loose on the spigots. The original copper seals fit snug on the spigots and had a 8mm ID. I don't know if these originals started out loose and crushed to fit snug on the spigot. Were the copper seals you used loose or tight on the spigots? Thanks. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:28 AM |
