Bleeding Brakes, Trouble with one caliper |
Deusexmachina77 |
Mar 25 2023, 10:13 AM
Member Group: Members Posts: 93 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I replaced the two front calipers with rebuilt calipers. The system was drained. I bleed the brakes starting in the rear and going to the front. I've run into an issue with the driver's side front caliper.
I have fluid making it to the caliper, as the bottom has fluid coming out with no air bubbles. But when I went to the top bleeder, I only got air. It never filled up with fluid. I removed the bleeder screw to make sure it wasn't clogged. We peddled the car continuously, and only just air. This went on for a while.(IMG:style_emoticons/default/headbang.gif) There are no fluid leaks in the system. Any thoughts would be welcome. |
Deusexmachina77 |
Mar 25 2023, 11:50 AM
I tried for 20 min. Nothing is coming out of the top bleeder screw, and nothing is leaking. I even removed the screw. Not a drop.
r_towle |
Mar 25 2023, 12:35 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I tried for 20 min. Nothing is coming out of the top bleeder screw, and nothing is leaking. I even removed the screw. Not a drop. sadly....push pedal to floor, tighten bleeder...then do that again and again. pumping just pushes air in an out. I use a vacuum bleeder, its easier. rich |
Lo-Fi Version | Time is now: 20th May 2024 - 07:51 PM |
