Bleeding Brakes, Trouble with one caliper |
Deusexmachina77 |
Mar 25 2023, 10:13 AM
Member Group: Members Posts: 89 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I replaced the two front calipers with rebuilt calipers. The system was drained. I bleed the brakes starting in the rear and going to the front. I've run into an issue with the driver's side front caliper.
I have fluid making it to the caliper, as the bottom has fluid coming out with no air bubbles. But when I went to the top bleeder, I only got air. It never filled up with fluid. I removed the bleeder screw to make sure it wasn't clogged. We peddled the car continuously, and only just air. This went on for a while.(IMG:style_emoticons/default/headbang.gif) There are no fluid leaks in the system. Any thoughts would be welcome. |
emerygt350 |
Mar 26 2023, 02:44 PM
Advanced Member Group: Members Posts: 2,080 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
We double checked the venting this morning and did another bleed across all brakes as well. He really enjoys it, and my car can lock them up now with almost perfect balance (no pulling to either side).
Glad I checked the venting again. Driver inside was dragging and passenger outside was about .o10 rather than the .004. I would say that both clymers and Chilton's say .008 on the venting but that seems a bit excessive. |
Lo-Fi Version | Time is now: 30th April 2024 - 10:41 AM |
