Bleeding Brakes, Trouble with one caliper |
Deusexmachina77 |
Mar 25 2023, 10:13 AM
Member Group: Members Posts: 89 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I replaced the two front calipers with rebuilt calipers. The system was drained. I bleed the brakes starting in the rear and going to the front. I've run into an issue with the driver's side front caliper.
I have fluid making it to the caliper, as the bottom has fluid coming out with no air bubbles. But when I went to the top bleeder, I only got air. It never filled up with fluid. I removed the bleeder screw to make sure it wasn't clogged. We peddled the car continuously, and only just air. This went on for a while.(IMG:style_emoticons/default/headbang.gif) There are no fluid leaks in the system. Any thoughts would be welcome. |
emerygt350 |
Mar 25 2023, 03:42 PM
Advanced Member Group: Members Posts: 2,080 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I use a ten year old. I open, he pushes n holds, I close, he releases. It is father son bonding at its best.
914e |
Mar 26 2023, 11:05 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
930cabman |
Mar 27 2023, 01:57 PM
Advanced Member Group: Members Posts: 3,005 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I use a ten year old. I open, he pushes n holds, I close, he releases. It is father son bonding at its best. I ran out of ten year olds, now I have bleed brakes on Sundays when the 20 year olds show up for Sunday dinner. +1, will the same thing hold for 30 and 40 y/o daughters, or maybe we can move into the next generation |
Lo-Fi Version | Time is now: 30th April 2024 - 10:11 AM |
