Bleeding Brakes, Trouble with one caliper |
Deusexmachina77 |
Mar 25 2023, 10:13 AM
Member Group: Members Posts: 89 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I replaced the two front calipers with rebuilt calipers. The system was drained. I bleed the brakes starting in the rear and going to the front. I've run into an issue with the driver's side front caliper.
I have fluid making it to the caliper, as the bottom has fluid coming out with no air bubbles. But when I went to the top bleeder, I only got air. It never filled up with fluid. I removed the bleeder screw to make sure it wasn't clogged. We peddled the car continuously, and only just air. This went on for a while.(IMG:style_emoticons/default/headbang.gif) There are no fluid leaks in the system. Any thoughts would be welcome. |
Deusexmachina77 |
Apr 1 2023, 07:16 AM
Finally got everything back together.
I ended up using a cheap ($11) cup from Autozone. My peddle pumper (wife) got a little tired but it worked well. The cup has a tube inside to keep air from reentering the system. I tried a vacuumed bleeder but the amount of fluid I went through was excessive. And all the bubbles it generated around the bleeder screws made it impossible for me to know if the line was clear. Thanks for all your help and advise. |
Lo-Fi Version | Time is now: 30th April 2024 - 01:11 PM |
