1970 1.7L Tangerine for Sale, Details and Pictures to Follow |
tvdinnerbythepool |
Mar 26 2023, 03:13 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Relisting now that Spring has arrived (ish)
For Sale: 1970 Porsche 914 1.7l in Tangerine I am selling my 914 after 5 years of ownership. I purchased this car in Seattle in 2018 and I believe this has always been a PNW car. I’m hoping to sell through the forum as this has been home for the car (and I) since the first day I brought it home and thought “oh crap, how do I work on this thing!” The forum has been a tremendous help while I have rebuilt and restored a lot on this vehicle. Huge thanks to Mark @ 914rubber, 914Werke, Mepstein and all the guys on the forum for guiding me and helping me source parts. Asking $20,000 1.7L with D-jet, Duck tail and Riviera Wheels (wheels included in sale but not installed) This car has always lived inside under a car cover with me and I believe was also the case with prior owner The gentleman I purchased the vehicle from had the starter replaced, transmission rebuilt and clutch replaced during his ownership, I believe sometime in 2017. Many labor intensive and, let’s be honest, somewhat miserable repairs have been accomplished on this including but not limited to the Hell Hole repair, Rebuilding Suspension and Calipers, Bearings, Expensive wiring harnesses, leaky oil seal replacement etc. It’s been a labor of love that the next owner will get to enjoy as most of the big ticket items have been addressed. Below are all the items that have been replaced, rebuilt, restored, rejuvenated etc New since car was purchased in 2018 -Wiring harnesses for Engine and Ignition (Jeff Bowlsby (engine) and 914rubber(ignition)) -123 Distributor -Bosch Coil, Spark Plugs and Wires -Battery Tray and Right side Engine Tray Sheet metal -Thermostat, Thermostat Cable -Cylinder Head Temp Sensor -o2 bung welded onto exhaust for tuning -Stainless Fuels lines front to back, tunnel and engine bay (no more plastic lines!) -Bosch fuel pump relocated to front trunk -Fuel tank sock -Fuel Filter -Throttle Cable -Shifter bushings front to back -Engine Seals replaced -Vacuum lines front to back as well as throttle body plenum, gaskets and intake manifold gaskets -Exhaust surround fresh air hoses -Engine bay rain tray (914 Rubber) -Trickle Charger included -Front and Rear Rotors and Pads with Rebuilt Calipers -19mm Master Cylinder (914rubber) -Rubber brake hoses -Rear Suspension: 914rubber Springs, Bilstein Struts, 914rubber Trailing Arms and Bushings -Front Suspension: 914rubber Bushings and Bilstein Struts -Tie Rods and Ball Joints -Front and Rear wheel bearings -Electric washer fluid pump conversion and lines with dash button -Pedal cluster wooden board -Transmission flush -Speedometer Input Shaft and Seal kit (914rubber) -New Stainless Wheels with OEM 914 Hub Caps (Original Rivieras included) -Plastic dash cover -Door Panels (914 Rubber) -Carpet set (not installed) -Custom 914 embroidered floor mats -Sun visors (914rubber) -JVC Bluetooth Stereo with Microphone -4 Rockford Fosgate Speakers, 2 x 914rubber speaker housings -Blaupunkt Subwoofer -Cellphone holder (Modified ash tray with cell phone holder, removable, original included) -Center Console with Speakers, Cupholders and Subwoofer Control (Not OEM, All removable) -Cigarette lighter/12v power outlet -LED bulbs for gauges (914rubber) -Turn signal lenses -Dome light lens and switch -Door switches for dome light -Fresh bulbs throughout -Car Cover Rebuilt/Replaced -Rebuilt Brake Calipers -Replaced AAR Valve -Rebuilt Manifold Pressure Sensor (Tangerine Racing kit, now tunable on car with o2 bung plug in exhaust) -Rebuilt Pedal Cluster with Brass Bushings -CV joints serviced and new safety wired bolts -Converted to later model air intake with paper gasket (Original oil air filter housing included) -Bursch Exhaust with O2 bung welded in (Last owner installed exhaust, we had bung welded in) -Driver door deposit box sourced and installed -Valves adjusted and fresh valve cover gaskets -Fuel Injectors serviced Compression Checks #1/120 #2/128 #3/125 #4/135 Tires have lots of life left in them. They are Michelin 195/60R15. What’s left? At some point the seats could use some new covers. I have recovered (over the original material) the seat bottoms, easily removed. The paint has some imperfections but overall still shines and looks great! It is a repaint of the original tangerine, not sure from when. It is smothered in wax and comes with a cover to keep it protected! I hope this car finds a great home. I have really enjoyed owning it and my goodness have I learned lots of new things! If you’d like to see more pictures or ask more about the car than is listed above, let me know and I’ll do my best to accommodate. Car is located in Olympia, WA. Come take a look and see if this is the right car for you! 2 totes of spare parts and bonus extras included. While I am selling I am not desperate for a quick sale. I want the car to go to a great owner for the right price and will happily take care of the old girl until that day comes. |
tvdinnerbythepool |
Mar 26 2023, 03:17 PM
tvdinnerbythepool |
tvdinnerbythepool |
Mar 26 2023, 03:18 PM
tvdinnerbythepool |
tvdinnerbythepool |
Mar 26 2023, 03:22 PM
tvdinnerbythepool |
tvdinnerbythepool |
Mar 26 2023, 03:27 PM
tvdinnerbythepool |
Mar 26 2023, 03:28 PM
tvdinnerbythepool |
tvdinnerbythepool |
Mar 26 2023, 03:29 PM
tvdinnerbythepool |
Mar 26 2023, 03:30 PM
FRUNKenstein |
Mar 26 2023, 08:29 PM
Member Group: Members Posts: 109 Joined: 25-May 20 From: Overland Park, KS Member No.: 24,308 Region Association: Upper MidWest |
Seems like a reasonable ask for a vehicle with that much work done. Great color. You might want to post a couple of pics of the longs.
Seats are an easy fix and relatively inexpensive. Good luck with the sale! |
jhynesrockmtn |
Mar 28 2023, 06:53 AM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
jhynesrockmtn |
Mar 28 2023, 06:45 PM
I just re-read everything you did to this car. That is quite the list. I also just drove mine to work and ran errands today. I know folks sometimes diss the early cars but if the bushings are done they shift ok and the 1.7 is a fun little engine. This is a nice car someone should jump in for that price. Is the ducktail easy to remove? I assume it is on with adhesive? I personally don't care for them much. If it doesn't sell soon I'd remove that and stick it on BAT with you're asking price as the reserve.
burlybryan |
Mar 28 2023, 07:30 PM
Member Group: Members Posts: 100 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Very fair price for the amount of work/sweat/tears put into it. One of my favorite colors - and looks great with steelies. Hope it sells quickly for you.
tvdinnerbythepool |
Mar 29 2023, 09:38 AM
Thanks for all the kind words! Greatly appreciated. Will list some more pics soon to include underside of the car and the longs.
tvdinnerbythepool |
Mar 29 2023, 11:34 AM
tvdinnerbythepool |
Mar 29 2023, 11:36 AM
tvdinnerbythepool |
Mar 29 2023, 11:39 AM
Patch repair in the passenger side. I believe it was a 2 fold issue that I repaired. Partial rust due to the battery tray and typical passenger side issues. The other was due to the prior owner using the floor as a jack point this crating a nice hole. Either way all rust was cut out. Inside the cavity was wire brushed and por15 applied as far as possible and then welded up. More POR 15 and then car undercoat spray. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:26 PM |
