Help - need engine advice, Fan Pulley has play in it |
tabwb |
Mar 29 2023, 03:38 PM
Newbie Group: Members Posts: 10 Joined: 28-March 20 From: New Jersey Member No.: 24,066 Region Association: MidAtlantic Region |
So, I think it's time to go to the well and throw this dilemma out to the masses. I'll cut to the chase - my 1976 had a 1.7 engine in it when I bought the car. I knew that it wasn't the right engine so my nephew and I rebuilt a 2.0 engine he had picked up. We picked up the necessary rebuild kits from 914 rubber, auto atlanta, pelican, etc. - all new stuff on the inside. Block sent out, machined where applicable, etc. Dropped the 1.7, put in the 2.0 - all good so far. We put about 700 miles on the car with the 2.0 and recently, during a short drive, he heard a "funny" noise. Upon inspection I noticed that the "fan assembly" had some play in it - that is, the pulley itself was able to be wiggled about 1/8 to 1/4 inches fore to aft (horizontally). The pulley bolts are tight, no issue there...it's that the driveshaft (pulley to crank to flywheel) has a front-to-back play the distance noted. Now, I will drop the engine and trans...but what are the chances that engine-internals are damaged (bearings, pistons, rings, etc.)? I'd love to get away with just a few spacers on the back end, reset the flywheel and put it all back together and load it back in but am I just asking for trouble? Is it worth the risk or am I looking at another complete rebuild?
Any advise at all would be helpful and thanks in advance - you folks have saved me before. WB |
technicalninja |
Mar 29 2023, 08:33 PM
Senior Member Group: Members Posts: 1,184 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Before I dropped the engine, I would verify that the movement felt at the pully could also be felt in the flywheel access hole.
.250 is a bunch! What was crank endplay during your build? |
ClayPerrine |
Mar 30 2023, 06:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Before I dropped the engine, I would verify that the movement felt at the pully could also be felt in the flywheel access hole. .250 is a bunch! What was crank endplay during your build? (IMG:style_emoticons/default/agree.gif) This sounds like the crankshaft end play is not set correctly. |
Lo-Fi Version | Time is now: 4th May 2024 - 04:25 PM |
