Help - need engine advice, Fan Pulley has play in it |
tabwb |
Mar 29 2023, 03:38 PM
Newbie Group: Members Posts: 10 Joined: 28-March 20 From: New Jersey Member No.: 24,066 Region Association: MidAtlantic Region |
So, I think it's time to go to the well and throw this dilemma out to the masses. I'll cut to the chase - my 1976 had a 1.7 engine in it when I bought the car. I knew that it wasn't the right engine so my nephew and I rebuilt a 2.0 engine he had picked up. We picked up the necessary rebuild kits from 914 rubber, auto atlanta, pelican, etc. - all new stuff on the inside. Block sent out, machined where applicable, etc. Dropped the 1.7, put in the 2.0 - all good so far. We put about 700 miles on the car with the 2.0 and recently, during a short drive, he heard a "funny" noise. Upon inspection I noticed that the "fan assembly" had some play in it - that is, the pulley itself was able to be wiggled about 1/8 to 1/4 inches fore to aft (horizontally). The pulley bolts are tight, no issue there...it's that the driveshaft (pulley to crank to flywheel) has a front-to-back play the distance noted. Now, I will drop the engine and trans...but what are the chances that engine-internals are damaged (bearings, pistons, rings, etc.)? I'd love to get away with just a few spacers on the back end, reset the flywheel and put it all back together and load it back in but am I just asking for trouble? Is it worth the risk or am I looking at another complete rebuild?
Any advise at all would be helpful and thanks in advance - you folks have saved me before. WB |
technicalninja |
Mar 30 2023, 09:21 AM
Senior Member Group: Members Posts: 1,184 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
The real question from the OP is "should I tear it down for inspection?"
We are all real good at giving advice on how to check and what to look for but no-one has answered the direct question yet. I asked about differences in 1.8 and 2.0 gasket sets and had 6 suggestions before DaveP answered my root question... The answer that the OP is looking for from my perspective. If, the thrust play was across the entire crank and the front pully is not loose. And, I had hit my thrust target of .004 during the build... I'd be a HONKED DONKEY! It would come ALL the way down as the only thing that might cause that is complete destruction of the thrust flanges on the main bearing. Lots of other engines have separated thrust bearing that can fall out if clearances were not correct. The Type 4 is built on to the main bearing and cannot drop out like a Mazda NB and most of the Toyota stuff. No way I'd try to cheap shit that if I really had thrust clearances the OP described. It might be cheap to fix now. Have it come apart at speed and you might be looking for the entire engine... |
Lo-Fi Version | Time is now: 4th May 2024 - 11:18 PM |
