turn signals, share flasher relay |
80cap |
Mar 30 2023, 07:50 AM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Does the turn signals share the flasher relay?
If not which relay is it? thanks Brian |
76-914 |
Mar 30 2023, 08:36 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If your flashers work the relay is good. If the turn signals aren't working & the flashers are then you have a bad turn signal assume or a faulty connection or burned out lampoon. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 12:18 PM |
