New style safety belt installation, Who has done it? |
draganc |
Mar 30 2023, 03:23 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hello folks and happy spring!
I didn’t feel comfortable with my original safety belts on my ‘75 teener and ordered some new placements from and made in Germany. The belts we advertised as a match for my ‘75 2.0 but they are not really a plug and play setup. The oem has a chrome belt guide mounted behind the retractor, which the new one doesn’t have. However, the new belt has a pivoting plastic belt guide, pointed towards the front. A few questions: 1) would you remove and transfer the oem chrome belt guide? 2) if not to 2), would you space/shim out to new retractor of the thickness of the “missing” belt guide? 3) the new retractor has the pin missing, which the oem has to fixates the belt guide and the oem retractor. Is the pin necessary if not used with the oem belt guide? Thanks for sharing your insight and experience!! dc |
rjames |
Mar 30 2023, 05:00 PM
I'm made of metal Group: Members Posts: 3,920 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I think you need the pin to keep the assembly from rotating. Depending on the design, the locking mechanism might not work correctly if it's rotated- at least that's how they guy I talked to from Seatbelt Planet explained it to me several years ago. The one from Seatbelt Planet looks like it comes with all hardware needed (and the pin). I have a set still in a box that I test fitted and they worked fine, but am holding off installing them for now because I found some NOS belts. I know others here have installed them without any issues.
Seatbelt Planet Porsche 914 '73-'76 Maybe contact the your seller and see if they sell an adapter plate with the pin? If not, maybe you can buy just the plate with the pin from Seatbelt Planet. |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:24 PM |
