> Battery Charging System, Battery not charging
Schmaz356
post Apr 20 2023, 10:46 AM
Post #21
I am building a 914-6 and I have an issue where the battery does not charge. Basically everything is new on the car (alternator, voltage regulator, battery & cables). The car runs fine but just will not charge the battery. I have checked the grounds on the body and at the transmission. The belt seems fine and is new. I pulled the battery and the regulator and brought it to a shop where they said it was putting out 14.2V using my regulator.
My Alternator wires are as follows;
Red from B+ to Starter
Black from DF to DF on the Regulator
Brown from D- to D- on Regulator
Blue from D+ to D+ on Regulator and then to the Dash Battery Light. (which is on all of the time)
Ground from D- to engine case.
When I put the system back together, I checked the continuity of each cable to assure myself it wasn't just a pulled connector or broken wire. When the car is running and reved to 2,000 RPM I still only get battery voltage.
Please help with any thoughts on what I should check next. Thanks.
Schmaz356   Battery Charging System   Apr 20 2023, 10:46 AM
windforfun   Try a different voltage regulator. It should be p...   Apr 20 2023, 11:09 AM
porschetub   Try a different voltage regulator. It should be ...   Apr 20 2023, 07:56 PM
Schmaz356   Thanks for the input. One other thought. I read on...   Apr 21 2023, 06:17 AM
davep   The alternator light in the instrument CANNOT be a...   Apr 21 2023, 08:38 AM
StarBear   The alternator light in the instrument CANNOT be ...   Apr 21 2023, 08:45 AM
ClayPerrine   [quote name='davep' post='3072804' date='Apr 21 2...   Apr 21 2023, 10:46 AM
Spoke   On a 914, the bulb must be an original 12 volt, ...   Apr 21 2023, 11:34 AM
ClayPerrine   [quote name='ClayPerrine' post='3072832' date='Ap...   Apr 21 2023, 11:48 AM
Spoke   I am building a 914-6 and I have an issue where t...   Apr 21 2023, 10:25 AM
dr914@autoatlanta.com   do you have a replacement alternator with a built ...   Apr 21 2023, 11:04 AM
Schmaz356   Thanks to everyone. The issue was the fact I used ...   Apr 22 2023, 09:14 AM
brant   You have to put a one way resistor into circuit W...   Apr 22 2023, 09:41 AM
Superhawk996   You have to put a one way resistor into circuit ...   Apr 22 2023, 10:40 AM
brant   Here is our racecar wiring   Apr 22 2023, 10:38 AM
brant   Correct. Diode Old man’s disease Plus I really ...   Apr 22 2023, 10:43 AM
Schmaz356   When I saw the symbol I knew it was a diode. Thank...   Apr 23 2023, 06:49 AM
Schmaz356   Brant; One more question. I installed the diode li...   Apr 24 2023, 09:17 AM
brant   I don't know... thought that the light would ...   Apr 24 2023, 09:23 AM
Schmaz356   Brant; One more question. I installed the diode li...   Apr 24 2023, 09:57 AM
Schmaz356   Okay, Thanks.   Apr 24 2023, 09:58 AM
- Lo-Fi Version Time is now: 9th May 2025 - 06:37 PM
