Factory 6 oil lines |
sixaddict |
May 6 2023, 06:33 AM
Senior Member Group: Members Posts: 801 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Ar3 these the same configuration as original…..for some reason they don’t “seem” to be….but haven’t had one in front of me for a while.
Thanks Attached thumbnail(s) |
gms |
May 6 2023, 07:23 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
They look correct but without actual measurements I cannot confirm
fixer34 |
May 25 2023, 07:39 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Obviously aftermarket as the ends are different. Something I discovered when replacing the long hose (I reused the factory ends) to the oil cooler is you want one with the 90 degree bend already formed into the hose. It tends to kink otherwise. I had to put a couple hose clamps on mine to prevent it pinching at the bend.
sixaddict |
May 28 2023, 10:24 AM
Thanks!
Lo-Fi Version | Time is now: 13th May 2024 - 09:11 PM |
