Pacemaker Dangers |
Pacemaker Dangers |
DBF |
May 7 2023, 11:10 AM
Member Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I just had heart surgery and now need a pacemaker. When I told the medical team I own 914 with an engine a foot or two from my heart one persons strongly suggested not driving it. Anyone else here with pacemakers and what is your experience with motors. Thanks - Doug
willieg |
May 7 2023, 11:35 AM
Member Group: Members Posts: 132 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California |
I have a pacemaker and read up on everything after installation. I also own a 914 with a Subaru 3.0 engine. I know I am not supposed to lie flat on the engine because of proximity to electro-magbnetic waves but do everything else associated with normal car stuff. My main objection to the pacemaker is that I can no longer MIG weld, which I used to really enjoy. I still gas weld but it isn’t the same. I also could not go into the bowels of Hoover Dam because of the huge generators. There are some other minor inconveniences but better than the alternative. Good luck with the life change.
Mikey914 |
May 7 2023, 02:17 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you are truly concerned, I’m sure that you could put up a barrier on the inside of the firewall. Or heck just inside of the engine compartment.
Superhawk996 |
May 7 2023, 02:43 PM
914 Guru Group: Members Posts: 5,822 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
You can’t prevent EMF from getting inside the cabin short of turning it into a mesh shielded Faraday cage complete with a fine metallic mesh over all glass.
I’m not a doctor and can’t give you any advice there. However, if they are worried about the ancient ignition system of a 914 running a terribly weak coil, you may want to talk to them about modern cars which have way more EMF. Since 2010 there has been a massive proliferation of devices in cars that have way more EMF sources such as modems, WiFi, Bluetooth, high voltage coils, CAN bus communication, electric motors for everything. Electric vehicles, batteries, and high voltage drive motors are even worse! You may want to seek out a more specialised medical expert opinion on EMF than your current team has offered up and/or to clarify risks of more modern vehicles to you vs. your 914. |
StarBear |
May 7 2023, 04:32 PM
Senior Member Group: Members Posts: 1,884 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Use “R” resistor spark plugs? (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif)
wonkipop |
May 7 2023, 05:24 PM
Advanced Member Group: Members Posts: 4,297 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
I just had heart surgery and now need a pacemaker. When I told the medical team I own 914 with an engine a foot or two from my heart one persons strongly suggested not driving it. Anyone else here with pacemakers and what is your experience with motors. Thanks - Doug they could be correct. they would not have cautioned without good reason. the alternator is right behind you and close. you can ask a good medico about it. the caution you got was probably very conservative. you do have to be very close to the electrical field. very close. 6 inches in most cases. so i guess the 914 alternator is in borderline territory. and it would generate a strong electrical field as its a charger device. i have an old mate with a pacemaker. and there is a list of equipment (makes and models) issued by heart foundation (of australia) for caution in relation to proximity of certain devices. as others note here, there are a lot of electrical fields in modern cars a lot stronger than those in older cars. ie electric vehicles! i'd add a lot of the equipment in modern cars is also shielded. but there are electrical fields everywhere these days. |
DBF |
May 7 2023, 07:33 PM
Thanks everyone for the comments. Now hearing my heart surgery complication may be more severe and pacemaker dangers worse than other pacemaker wearers. Looks like a lot of research ahead
Freezin 914 |
May 7 2023, 07:43 PM
Senior Member Group: Members Posts: 857 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Thanks everyone for the comments. Now hearing my heart surgery complication may be more severe and pacemaker dangers worse than other pacemaker wearers. Looks like a lot of research ahead Wishing you good luck with everything my friend. (IMG:style_emoticons/default/beerchug.gif) |
Dr Evil |
Should not be an issue. I will copy and paste some guidance that we use and to further look into this I have messaged a few cardiologists and EP in a physician car group that Im in as they get the nuance of the question.
From Uptodate, one of our resources for med info and guidelines: "AVOIDING ELECTROMAGNETIC INTERFERENCEAlthough contemporary pacemakers are less susceptible to interference than older models, electromagnetic energy can interfere in some cases. Thus, experts advise that people with pacemakers be aware of the following: Household appliances — Pacemaker manufacturers do not recommend any special precautions when using normally functioning common household appliances such as microwave ovens, televisions, radios, toasters, and electric blankets. Cellular phones — People with a pacemaker or a defibrillator should know that items with strong magnetic fields (eg, cellular phones with magnets for wireless charging [iPhone 12], magnetic accessories such as certain “smart watches”) can affect the function of the device if they are very close (less than six inches) to their device. Cell phones without strong magnets are unlikely to cause problems with pacemakers or defibrillators. If you have a pacemaker or a defibrillator, the safest strategy is to use your cell phone at the ear on the side opposite the cardiac device. When you are carrying your phone, keep it in a pocket or bag below your waist. If you’re not sure whether your phone or watch is likely to cause problems with your cardiac device, check with the manufacturer or your doctor. Anti-theft systems — Electromagnetic anti-theft security systems are often found in or near the workplace, at airports, in stores, at courthouses, or in other high-security areas. Although interference with a pacemaker is possible, it is unlikely that any clinically significant interference would occur with the transient exposure associated with walking through such a field. Based upon several studies and observations, experts advise that patients with pacemakers should: ●Be aware of the location of anti-theft systems and move through them at a normal pace ●Avoid leaning on or standing close to an anti-theft system Metal detectors at airports — Similar to antitheft systems, metal detectors at airports can potentially interfere with pacemakers, although this is unlikely. Such exposure has been shown to cause interference in some cases and may be related to the duration of exposure and/or distance between the security system and the pacemaker. Metal detectors will likely be triggered by the presence of a pacemaker and therefore at places such as airports, it will be important for individuals with pacemakers to carry an identification card for their pacemaker, and airport personnel will likely prefer to do a manual search. External electrical equipment — External electrical fields do not seem to cause a problem for most people with a pacemaker. However, in workplaces that contain welding equipment or strong motor-generator systems, because interference can inhibit pacing, it is recommended that a person with an implanted cardiac device remain at least two feet from external electrical equipment, verify that the equipment is properly grounded, and leave the immediate locale if lightheadedness or other symptoms develop." |
Dr Evil |
May 7 2023, 07:45 PM
Thanks everyone for the comments. Now hearing my heart surgery complication may be more severe and pacemaker dangers worse than other pacemaker wearers. Looks like a lot of research ahead I feel you. Been dealing with heart shit for 5 yrs, and had valve replace and repair last December. Hang in there and ask lots of questions of your team. |
burton73 |
May 7 2023, 09:12 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have an inside of my hart pacemaker on one side and I went over this with my Electro specialists on my heart peacemakers their answer was, this if electric Welding my pacemaker would not work right. It would not damage the unit but as my pacemaker paces 22% of the time, my hart may beat to low, and I could pass out. I sold my welding equipment for that reason.
Stay healthy my friends, Bob B |
Dr Evil |
May 7 2023, 09:14 PM
Update, you need 12" from ignition system, which is not an issue, and per the guidelines I already posted. That is generic, though. If you want to DM me your model type/number I have a cardiology friend that offered to pull up the details and let me know if yours is even a concern.
davep |
May 8 2023, 06:58 AM
I defer to Dr Evil of course, but the engine is almost in a Faraday cage as it is. Generally you will be about 18 inches away from the ignition system.
Steve |
May 8 2023, 07:42 AM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Beware…. Make sure you push for a pace maker that supports MRI’s. Some don’t.
burton73 |
May 8 2023, 09:44 AM
Mikey914 |
If it’s unaffected by an MRI, I’d suspect the 914 would not be an issue.
Steve |
May 8 2023, 11:08 AM
My Mom's pacemaker brand/model did not support MRI's and my Dad's does. Big PIA when we needed an MRI when she had a stroke.
emerygt350 |
May 8 2023, 02:10 PM
Advanced Member Group: Members Posts: 2,096 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I wonder if a gauss meter or something would be helpful? They are not expensive considering the value in your case.
tpines |
May 10 2023, 10:30 AM
Member Group: Members Posts: 74 Joined: 12-November 08 From: San Diego Member No.: 9,745 Region Association: Southern California |
I just had heart surgery and now need a pacemaker. When I told the medical team I own 914 with an engine a foot or two from my heart one persons strongly suggested not driving it. Anyone else here with pacemakers and what is your experience with motors. Thanks - Doug they could be correct. they would not have cautioned without good reason. the alternator is right behind you and close. you can ask a good medico about it. the caution you got was probably very conservative. you do have to be very close to the electrical field. very close. 6 inches in most cases. so i guess the 914 alternator is in borderline territory. and it would generate a strong electrical field as its a charger device. i have an old mate with a pacemaker. and there is a list of equipment (makes and models) issued by heart foundation (of australia) for caution in relation to proximity of certain devices. as others note here, there are a lot of electrical fields in modern cars a lot stronger than those in older cars. ie electric vehicles! i'd add a lot of the equipment in modern cars is also shielded. but there are electrical fields everywhere these days. Hi. I'm sure your friend with the pacemaker is aware of this potential danger but if not please let him know as well. Cheers! |
DBF |
May 14 2023, 06:22 PM
I'm home from the hospital after 16 days and working to regain strength. Thanks for all the information and offers to help. It's looking like I won't need to sell my barn find BB before I even get it back on the road! I'll be sure to reach out as I begin my research. Thanks again, Doug
Lo-Fi Version | Time is now: 16th May 2024 - 02:12 PM |
