Pacemaker Dangers |
Pacemaker Dangers |
mlindner |
May 15 2023, 07:47 AM
Senior Member Group: Members Posts: 1,525 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Doug, what is your location in WI, I'm on Lake Wisconsin north of Madison. Mark
burton73 |
May 16 2023, 02:02 PM
burton73 Group: Members Posts: 3,538 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I called my In heart (leadless) pacemaker manufacture today to ck on a few things after I was at Cedars Sinai hospital for my yearly pacemaker Ck up. As far as the ignition source goes, they say 12 inches away is fine. I am inclosing some info from them Stay healthy my friends.
Bob B Dear Mr. Burton, Thank you for contacting Medtronic Patient Services. If you do choose to weld after consulting with your physician, follow these welding safety precautions to minimize the risk of interfering with your implanted heart device: • Limit welding to currents less than 160 amps • Work in a dry area with dry gloves and shoes. • Maintain a 2-foot (60 centimeter) distance between the welding arc and heart device. • Keep the welding cables close together and as far away as possible from the patient’s heart device. • Place the welding unit approximately 5 feet from the work area. • Connect the ground clamp to the metal as close to the point of welding as possible. • Arrange the work so the handle and rod will not contact the metal being welded if they are accidentally dropped. • Wait several seconds between attempts when having difficulty starting a weld. • Work in an area that offers firm footing and plenty of room for movement Work with an informed person who understands these suggestions. • Immediately stop welding and step away from the area if the patient start feeling lightheaded or dizzy or if the patient believes their implantable defibrillator has delivered a shock Welding above 160 amps is not recommended, maintain at least 5 feet from the welding area and components for welders up to 400 amps. NOTE: There is no apron or vest that will effectively shield the Medtronic heart devices from the electromagnetic fields generated by the welding equipment. Welding precaution guidelines support the following types of welding machines: • EDM - Electromagnetic Discharge Machine • GMAW - Gas Metal Arc Welding types: • MIG - Metal Inert Gas welding • MAG - Metal Active Gas welding • SMAW or MMA - Shielded Metal Arc Welding or Stick Welding or Manual Metal Arc welding • GTAW or TIG – Gas Tungsten Arc • Welding or Tungsten Inert Gas • Helium arc • Plasma cutters • Gouging • Alternating Current (AC) or Direct Current (DC) To learn more about Medtronic implanted heart devices, please reference the websites below. You may also share the following links with family and friends: • medtronic.com: Learn more about Medtronic products • medtronic.com/patient-services/cardiac-emc-guide/index.htm: Understand electromagnetic field EMC_Guide.pdf ( 2.43mb ) Number of downloads: 27 EMC_Worksite_Patient_Standard_Letter_v1.2.pdf ( 102.61k ) Number of downloads: 28 |
DBF |
May 16 2023, 04:58 PM
Member Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I live in McFarland. Thanks for the info about welding. I have a dual lead Medtronic. Things are looking more positive for life with a pacemaker.
May 18 2023, 01:07 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
because this issue is what I do daily...and I am most likely going to get one in the future....
I am very concerned about this aspect. There are things I can avoid...EMF things. This bit will become harder to avoid as things become more connected. An example article, but the issue is very real, and very scary. https://www.ahajournals.org/doi/10.1161/CIR...0agency%20noted. |
DBF |
May 20 2023, 11:55 AM
When friends offer condolences about my heart problems, I tell them everyone just has to play the cards they are dealt, but when I read this article, I sometime feel mine are too often aces and 8's. Scary stuff.
Superhawk996 |
May 20 2023, 12:44 PM
914 Guru Group: Members Posts: 5,875 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
This bit will become harder to avoid as things become more connected. An example article, but the issue is very real, and very scary. https://www.ahajournals.org/doi/10.1161/CIR...0agency%20noted. Logan’s Run |
May 20 2023, 01:15 PM
This bit will become harder to avoid as things become more connected. An example article, but the issue is very real, and very scary. https://www.ahajournals.org/doi/10.1161/CIR...0agency%20noted. Logan’s Run So, I will be watching your heart rate and I will Brick your car and call an ambulance. Lol |
Lo-Fi Version | Time is now: 31st May 2024 - 10:45 PM |
