Sold 72 914 Track Car, Sold |
MrLeeS |
May 7 2023, 04:59 PM
Member Group: Members Posts: 62 Joined: 25-April 09 From: Albuquerque, NM Member No.: 10,300 Region Association: Southwest Region |
Selling my 72 track car. This is not built to any organization spec. Just for fun. The new engine was installed just pre-covid and broken in and used on 2 autocrosses. Side shift conversion. Super fun car torque monster. Specs:
Engine/Drive-train: 80 x 96 Biral Cylinders JE Forged Pistons Scat C35 cam Webcam LIfters 5.5" H-Beam Rods AA with ARP bolts Fat performance oil sump baffles Rebuilt 2L heads stock valves 100% full flow oiling system Oil thermostat mounted under pass rocker cover Large front mounted oil cooler Chromoly push rods Dellorto 40mm carbs Mallory Hyfire 6AL ignition box with 009 distributor. Lightweight flywheel Kennedy stage 2 pressure plate Rebuild side shift transmission 2 auto-x and some break in street driving. 1st gear has the downshift brake on the syncro Koni adjustable shocks rear with ground control adjustable perches and 200lb springs 17mm adjustable front sway bar. Interior: Renegade hybrids sport seats 5 point harnesses both sided Oil pressure and temp gauges. 340mm momo steering wheel aluminum floor board and pedals Weltmeister short shift (the shift knob isn't great, could use replaced) Aluminum door panels no back pad or carpeting Other stuff: Fiberglass front and rear hoods. Fiberglass back bumper Odessey PC680 lightweight battery This is a pretty solid car. Hell hole is good to go, battery tray is good. There is some bubling behind the driver door under the sail. some bubling on the pass fender near the a-pillar outer trailing arm ears reinforced with tangerine reinforcement plates All lights, wipers work but speedo inop, I haven't taken the time to see if its the cable or the speedo. angel drive is good. 2l Fuch wheels The Bad: This has been a track car a while, the back fenders have been bumped a couple times and fiberglass repaired on both sides, showing signs of cracking in the paint. repaired area paint isn,t a perfect match. It's a 40ft 40mph match. PO installed a cooler in the trunk that blew through the floor, i left it to ovoid having to plug a whole in the trunk floor. Closing: Sum of the parts is worth significantly more than the asking price. but I know the deal. $8000. Attached image(s) |
MrLeeS |
May 25 2023, 06:41 PM
Price dropped to 10k. This car has a title unlike a lot of other track cars. I would like to make room in the shop for another project. I am also including a nice back pad with the car. Put in the back pad, some carpet and you’d have a nice little street car.
Lo-Fi Version | Time is now: 23rd May 2024 - 02:41 PM |
