What did you do/recommend for 914/6 air cleaner to clear engine lid? |
Tdskip |
May 9 2023, 11:18 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
So the good news is that I'm down to this level of detail with the build (car is up and running).
Can I ask for ideas and recommendations for those running carbs that will clear the engine lid? Any specific vendor solutions I should be thinking about? Thanks! |
KSCarrera |
May 9 2023, 11:20 AM
Member Group: Members Posts: 309 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
On my factory 914/6, I ran regular K&N filters, with no clearance problems.
Tdskip |
May 9 2023, 11:39 AM
Good morning/afternoon. Thanks for the response.
Do I just need to track down the pretty common rain hat set up? |
sixaddict |
May 9 2023, 11:57 AM
Senior Member Group: Members Posts: 804 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
The only issue would be if you had 4 cylinder rain tray …..then answer is remove it.
Tdskip |
May 9 2023, 12:11 PM
Thanks for the response. Raintray has been removed so I should have some clearance.
Lucky9146 |
May 9 2023, 12:22 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,615 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
I'm running Weber 40's on PMO intake manifolds with Rain hats on my 3.0 and no clearance problems at all.
Hope this helps! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
BillJ |
May 9 2023, 12:27 PM
Senior Member Group: Members Posts: 1,098 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Same here. No.raintray with pmo/webers should work fine. I wonder how tall.stack.mfi would fare??
Attached thumbnail(s) |
ClayPerrine |
May 9 2023, 12:29 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Same here. No.raintray with pmo/webers should work fine. I wonder how tall.stack.mfi would fare?? I ran the K&N watershields on the 2.2 MFI Mag stacks with no clearance issues. Well, there were no clearance issues with the engine lid. I had to trim one edge of the watershield to clear the MFI pump lines. |
mlindner |
May 9 2023, 01:17 PM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Mine with 40 PMO's and there filters, rain tray delete with double GT engine lid.
Dion |
May 9 2023, 01:35 PM
RN Group: Members Posts: 2,766 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Webers with rain hats and GT lid.
Tdskip |
May 9 2023, 02:41 PM
Thanks, super helpful and great to see all the builds.
mb911 |
May 9 2023, 03:20 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
sixnotfour |
May 9 2023, 07:24 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
What Manifolds do you have ?? stock / tall ??
IronHillRestorations |
May 9 2023, 08:22 PM
Anything that allows any possibility of water getting in the carb throats is risky. More than one Porsche engine has hydro locked from rain water intrusion.
rgalla9146 |
May 9 2023, 08:27 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
What Manifolds do you have ?? stock / tall ?? I agree. The intake manifolds are important. My rainshields fit fine with stock 68mm Porsche manifolds. with 82mm PMO manifolds the pass. side had interference. The front engine mount on conversion cars is also an important part of the issue. |
mb911 |
May 10 2023, 04:50 AM
What Manifolds do you have ?? stock / tall ?? I agree. The intake manifolds are important. My rainshields fit fine with stock 68mm Porsche manifolds. with 82mm PMO manifolds the pass. side had interference. The front engine mount on conversion cars is also an important part of the issue. Yes absolutely 100%true |
930cabman |
May 10 2023, 05:49 AM
Advanced Member Group: Members Posts: 3,071 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Matt Romanowski |
May 10 2023, 05:53 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
mb911 |
May 10 2023, 01:49 PM
I did some basic clearances to make it work. I absolutely hate the k&n filters they filter terribly and the noise is to much for me anyways My /6 build may be coming together this year (fingers crossed) and I will be looking to use this setup. factory I believe If you notice mine is a converted 911 unit but Very happy with how it looks |
targa72e |
May 10 2023, 10:16 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I have had several different engines with factory air cleaners in my -6 conversion. With MFI everything fit fine with T-bars removed. Webers with tall manifolds required a little massaging like MB911. Standard height manifolds with Zeniths fit fine. I have had engine fill with water after being outside in heavy rain with stock air cleaners. I have Rain hats (with small mods) that use paper filters to test soon.
john |
Lo-Fi Version | Time is now: 21st May 2024 - 01:42 AM |
