What did you do/recommend for 914/6 air cleaner to clear engine lid? |
porschetub |
May 11 2023, 02:00 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I did some basic clearances to make it work. I absolutely hate the k&n filters they filter terribly and the noise is to much for me anyways (IMG:style_emoticons/default/agree.gif) ditched my K&Ns after filtration issues and also I got tired of the noise ,I swear there is somewhat less fuel smell also. Didn't use the stock paper filter as I picked up a quality BMC reusable filter for a great price , had to move one spring clip as it fouled the rear bulkhead ,a fiddley job but got it to work. I guess the real downside is the cost of the stock unit...prices have gone mad and the plastic ones are often melted due to back fires,mine was a bit cooked on one side but managed to repair it. |
live free & drive |
May 11 2023, 03:00 PM
Member Group: Members Posts: 159 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
K&N filters = cam lobe tip reducers...
sixaddict |
May 11 2023, 05:40 PM
Senior Member Group: Members Posts: 806 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
[Would you please elaborate
quote name='live free & drive' date='May 11 2023, 01:00 PM' post='3077197'] K&N filters = cam lobe tip reducers... [/quote] |
mb911 |
May 11 2023, 05:48 PM
914 Guru Group: Members Posts: 6,896 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
[quote name='sixaddict' date='May 11 2023, 03:40 PM' post='3077224']
[Would you please elaborate quote name='live free & drive' date='May 11 2023, 01:00 PM' post='3077197'] K&N filters = cam lobe tip reducers... [/quote] [/quote] They don’t filter well so lots of dirt makes it way into the engine. I did studies on this back in the day when I was building aircraft engines for a company |
live free & drive |
May 11 2023, 07:44 PM
Well the of all the places in an engine the part of the cam lobe profile furthest from the center axis in a high lift performance grind will see the highest overall contact pressure.
If you run an engine with a high cam lift and use K&N filters and the same engine with paper filters you will notice a very measurable lift difference after running less than a 1000 miles between the two scenarios - In my case with a 2 liter Alfa engine running .660" lift cams and an extremely ported head; the cams lost ~.080" lift with K&N filters. I replaced the cams, used paper filters and the same oil type - no more cam tip lift reduction (this was in the early '80's using Kendal GTX 20/50). I had the same problem in the late seventies with the piston rings in my dirt bikes after I got one of the "new" hp adding K&N filters. I did not cop on at that point why I kept having to replace the rings as the power faded quickly... |
Tdskip |
May 11 2023, 10:12 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I did some basic clearances to make it work. I absolutely hate the k&n filters they filter terribly and the noise is to much for me anyways (IMG:style_emoticons/default/agree.gif) ditched my K&Ns after filtration issues and also I got tired of the noise ,I swear there is somewhat less fuel smell also. Didn't use the stock paper filter as I picked up a quality BMC reusable filter for a great price , had to move one spring clip as it fouled the rear bulkhead ,a fiddley job but got it to work. I guess the real downside is the cost of the stock unit...prices have gone mad and the plastic ones are often melted due to back fires,mine was a bit cooked on one side but managed to repair it. Cost of a real one is presumed to be both worth the number of kidneys it will take. I bet it does help with noise. |
Tdskip |
May 11 2023, 10:14 PM
mb911 |
May 12 2023, 04:35 AM
Shortened the snorkel then a indent next to the latch |
Tdskip |
May 12 2023, 07:06 AM
Shortened the snorkel then a indent next to the latch Ah, so height wasn’t an issue then. Thanks |
Cairo94507 |
May 12 2023, 08:00 AM
Michael Group: Members Posts: 9,839 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
@MB911 Ben that looks terrific. I know the difference the stock filter housing makes when it comes to rain-hats and intake noise. Well worth it and it looks pretty stock too. Well done. (IMG:style_emoticons/default/beerchug.gif)
ClayPerrine |
May 12 2023, 11:16 AM
Life's been good to me so far..... Group: Admin Posts: 15,528 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
VaccaRabite |
May 12 2023, 11:47 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
There are always paper filters for IDF carbs. I'm not sure they have much more surface area then the K&N filters though. Which means that if they are filtering more, they are letting less airflow through.
Or you can go the other way and spend a bunch of money on ITG foam filters. Still a 10 micron oiled filter. Desert people seem to really like them. Zach |
sixaddict |
May 12 2023, 12:04 PM
So much for liking the “look”.
Still learning!……unfortunately… |
914Toy |
May 12 2023, 01:49 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
Shortened the snorkel then a indent next to the latch Ah, so height wasn’t an issue then. Thanks I have a stock six intake air filter housing on my 2.7 with Webers, and enjoy the ease of removal and replacement as well as the reduced intake noise. I did not need to modify it to fit, but reduced the snorkel length to increase it's intake diameter efficiency (theoretically anyway!). |
mb911 |
May 12 2023, 02:32 PM
Shortened the snorkel then a indent next to the latch Ah, so height wasn’t an issue then. Thanks I have a stock six intake air filter housing on my 2.7 with Webers, and enjoy the ease of removal and replacement as well as the reduced intake noise. I did not need to modify it to fit, but reduced the snorkel length to increase it's intake diameter efficiency (theoretically anyway!). It all depends on height of the engine mount. |
mb911 |
May 12 2023, 02:38 PM
Oops replied too soon. Mine still rubs in a few spots and that’s because 1 of two things. Possibly 3 . I use a stock manifold which I assume is short intakes. The engine mount is stock height to a factory six but might put the engine up too high. The other thing is could the hinges be a bit lower on mine than others? Absolutely. I need to clearance the engine lid in a few spots but no waaaaay in hell will I run K&N s again if I can
porschetub |
May 12 2023, 02:56 PM
K&N filters = cam lobe tip reducers... I always heard this: K&N Rockstoppers. Because everything smaller than a rock gets through. so true,I was concerned as after my engine went in I was test driving on very dusty roads,bought my K&Ns used but in good condition ,cleaned the filters and fitted them after a few drives and checked them to find they were very dirty even on the inside. Solvent washed them with K&N product and was amazed @ what came out,I had a set of Outerwears and fitted them as a further test and found the filters were now clean on the inside...told me what I already knew (IMG:style_emoticons/default/sad.gif) . |
campbellcj |
May 15 2023, 10:33 AM
I can't Re Member Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Or you can go the other way and spend a bunch of money on ITG foam filters. Still a 10 micron oiled filter. Desert people seem to really like them. Zach I used ITGs for a while - look great and suspect they filter better than K&N but have not checked for data on that. They are however unbelievably loud! Also no provision for water shielding on typical Weber applications but that was not an issue for me. Currently I'm running flat-top K&Ns (car never gets wet). I have some watershields in storage but they will not fit without a little modding. IIRC I do have PMO tall manifolds. |
brant |
May 15 2023, 11:39 AM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I run ITG’s and ear plugs on the racecar
But no noise restrictions out here They don’t last real long The foam starts to degrade …. Probably from the fuel vapors after 3? Or 4 years. I’m on my 2nd set |
Lo-Fi Version | Time is now: 14th June 2024 - 10:16 AM |
