Replacing 76 2.0 HE's with earlier models, What is involved? |
CLTAMT |
May 9 2023, 07:39 PM
Newbie Group: Members Posts: 10 Joined: 6-May 22 From: Charlotte NC Member No.: 26,521 Region Association: South East States |
Can you guys tell me what all is involved with replacing the restrictive CA heat exchangers on a 76 2.0 with a set of the free-flowing HE's off of a 73 2.0?
As I understand it there are some issues with the heat valves that need to be addressed? Can you clue me in? Thank you! (IMG:style_emoticons/default/driving.gif) |
Dlee6205 |
May 9 2023, 07:54 PM
Newbie Group: Members Posts: 45 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
Its a bolt-on swap but here's a quick list of things you will need...
Muffler Exhaust hanger Heat Exchangers Heat shield/guides under the engine J-Tubes going up through the engine tin S tubes underneath Elbows going to heater valves |
CLTAMT |
May 9 2023, 07:58 PM
VaccaRabite |
May 10 2023, 05:36 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You are in the south so you may not use heat. If so, all you need is the exchangers, muffler, hanger and gaskets.
Its a very simple change! Zach |
914Sixer |
May 10 2023, 06:10 AM
Heater valve cable are different. I believe this is what you were asking.
barefoot |
May 10 2023, 06:49 AM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Look here, the 75,76 parts are on the bottom,
http://www.autoatlanta.com/porsche-parts/h...rts§ion=202-15 |
CLTAMT |
May 10 2023, 08:03 AM
Look here, the 75,76 parts are on the bottom, http://www.autoatlanta.com/porsche-parts/h...rts§ion=202-15 Hi barefoot - I tried that link, unfortunately it didn't work. |
Mikey914 |
May 10 2023, 08:09 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Try this
https://914rubber.com/1975-76-heater-lever-...-cable-1-2-2468 May even have some J tubes in my personal stash. PM me if you want me to check. Attached thumbnail(s) |
dr914@autoatlanta.com |
May 10 2023, 08:37 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
if your heat exchangers are in good shape, keep them and do not replace with the early system you will gain virtually nothing, however you can remove the cat if it is a california car.
Converting means adding a lot of expensive plumbing besides the expensive heat exchangers and muffler and muffler bracket Can you guys tell me what all is involved with replacing the restrictive CA heat exchangers on a 76 2.0 with a set of the free-flowing HE's off of a 73 2.0? As I understand it there are some issues with the heat valves that need to be addressed? Can you clue me in? Thank you! (IMG:style_emoticons/default/driving.gif) |
CLTAMT |
May 10 2023, 08:46 AM
Thanks for responding fellows!
I purchased this car off of BAT last May that was in storage in CA for years. I had it delivered to a so-called '914 specialist' in my area to get it road worthy and it sat at his shop for 6 months, with nothing done. I finally ended up having to retrieve the car and take it to another shop where the work has been outstanding. The new shop almost has it ready, replacing all the underside rubber, fuel lines, a complete tune-up, master cylinder, brake lines, new tires, etc., etc.. All the CA smog crap was removed, the exhaust system and single-tube HE's removed, and '73 HE's installed, along with a new stock muffler. The only thing left to do is connect the HE's. Apparently there was more to it than I was aware of. My budget on this project is running low right now! Someone asked about needing heat here in the South. Yes, it gets cold here too and I would like to be able to use the car year around. But no, I won't need the heat until next fall. That's why I'm trying to get all the parts rounded up now and have them ready for the install later in the summer (after my wallet recovers! Ouch!) (IMG:style_emoticons/default/shades.gif) Thanks again for all your help! Larry (IMG:style_emoticons/default/bye1.gif) |
CLTAMT |
May 10 2023, 08:54 AM
if your heat exchangers are in good shape, keep them and do not replace with the early system you will gain virtually nothing, however you can remove the cat if it is a california car. Converting means adding a lot of expensive plumbing besides the expensive heat exchangers and muffler and muffler bracket Can you guys tell me what all is involved with replacing the restrictive CA heat exchangers on a 76 2.0 with a set of the free-flowing HE's off of a 73 2.0? As I understand it there are some issues with the heat valves that need to be addressed? Can you clue me in? Thank you! (IMG:style_emoticons/default/driving.gif) Too late George! I wish I had known beforehand! But I probably would have change it anyway at a later date. That little type 4 needs all the help it can get, even if it's only a couple of ponies! But I'm definitely using the stock FI. The HE's and muffler are already installed. Do you have all the other associated parts available? Thank George! |
May 10 2023, 08:55 AM
Sounds like the heavy lifting has been done for you
The remaining work, aside from replacing the heater box cable, is really simple and can be easily done as time allows and when you find the parts. For the cable….I’m thinking it needs to be longer. If you have a creative streak, and a good hardware store and maybe a good bicycle shop nearby…you can get by with a home made solution Pull handle, open lever on heater box Once you see the geometry of the new boxes installed….you will see what is required. It’s not terribly hard to replace the cable, just detail oriented and time consuming. Rich |
914werke |
May 10 2023, 09:27 AM
"I got blisters on me fingers" Group: Members Posts: 10,061 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Heater valve cable are different. I believe this is what you were asking. (IMG:style_emoticons/default/blink.gif) This is news to me. Ive done 10 or more back dates myself and have never had to change the heat blower pull cable due to it being longer /shorter? Do you have the 2 part #'s? |
914Sixer |
May 10 2023, 11:13 AM
Info
rjames |
May 10 2023, 12:57 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Heater valve cable are different. I believe this is what you were asking. (IMG:style_emoticons/default/blink.gif) This is news to me. Ive done 10 or more back dates myself and have never had to change the heat blower pull cable due to it being longer /shorter? Do you have the 2 part #'s? Ran into this when I backdated my exhaust many years ago. Driver's side was fine, but the passenger side was just a bit too short. You can still make it work, but likely the flap won't fully close. |
914werke |
May 10 2023, 01:02 PM
Interesting. (IMG:style_emoticons/default/idea.gif)
Like Ive said before you learn something every day with these cars. Ive never had an issue. I guess I live a charmed life (IMG:style_emoticons/default/rolleyes.gif) |
rjames |
May 10 2023, 01:37 PM
Just noticed that the tube leading to the passenger heater flapper on mine is different than I've seen in other pics. I think the one I'm using came with the SSI's I bought used a long time ago, and I used it because it was in better shape and more stout than what I had as the metal was slightly thicker than what the original was. It might be stainless steel.
Hard to tell from the photo because the angle they photos were taken at are different, but maybe the bend is just a bit less on it compared to the stock piece (shown in photo on the right) and that's why the issue with the cable? |
914werke |
May 10 2023, 01:40 PM
The tube on the R. is an aftermarket unit (notice no seams) I think George used to, or does sell those.
rjames |
May 10 2023, 01:44 PM
CLTAMT |
Thanks once again for the responses fellows! (IMG:style_emoticons/default/pray.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 01:01 PM |
