Dual 40 IDF'S really weird . . . ., defective Spanish casting???? |
ghettojet |
May 14 2023, 08:44 PM
Newbie Group: Members Posts: 6 Joined: 20-March 22 From: queens new york Member No.: 26,409 Region Association: North East States |
1.8 engine rebuilt by me.New Weber IDF's from CB Performance.
Engine is being bench run Fuel pressure 3.0lb,even tried a little less at one point. Good strong spark all around Timing is on. No gas in idle circuit cylinders #1 & 4 Mixture screws on this carb have no effect took apart carb,blew air through idle jet passages double checked float height. all good. Compression good engine has a few hours on it Finally I swapped carbs Problem follows the carb Now #2 & 3 not "participating" air correction 2.00 emulsion tubeF-11 Main 1.15 Idle .50 Venturi 28mm Only thing I can think here is that the actual casting is defective internally? Seems far fetched Am I missing something? not sure what I can do except return carb to CB Performance Would rather not do this Please advise |
Lo-Fi Version | Time is now: 16th May 2024 - 04:18 PM |
