Moulding, hang to the body? |
Pierre1973 |
May 15 2023, 02:27 AM
Newbie Group: Members Posts: 33 Joined: 7-May 22 From: new caledonia Member No.: 26,525 Region Association: None |
Hello everyone,
Do you know how to hang this part of the molding? An idea? In advance for all your always excellent answers. Attached image(s) |
ChrisFoley |
May 15 2023, 03:41 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The factory made four holes along the base of the sail panel. Spring clips attached to the moulding go thru the holes.
Pierre1973 |
May 15 2023, 04:02 AM
BeatNavy |
May 15 2023, 06:05 AM
I believe it's this -- number 14 in the diagram with 8 required per car:
http://www.autoatlanta.com/porsche-parts/h...n=99959132601#a (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ebayimg.com-17042-1684152333.1.png) Another source: https://www.pelicanparts.com/More_Info/9995...JUaAl6YEALw_wcB |
Mikey914 |
May 15 2023, 10:30 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
$2.99 a pop
https://914rubber.com/exterior-molding-clip Attached thumbnail(s) |
Root_Werks |
May 15 2023, 10:51 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
You should have little holes already for the clips:
Pierre1973 |
May 19 2023, 01:06 AM
rgalla9146 |
May 19 2023, 05:25 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Pierre, how many 914s are there on New Caledonia ? |
DRPHIL914 |
May 19 2023, 06:36 AM
Hello everyone, Do you know how to hang this part of the molding? An idea? In advance for all your always excellent answers. the main part of it will be held on by those clips but the end of it shown in your picture will be held by the other vertical trim piece that holds the window seal, that end tap goes under the vertical seal trim. Phil |
Lo-Fi Version | Time is now: 16th May 2024 - 04:17 AM |
