Front sway bar add, Need u clip location |
North Coast Jim |
May 18 2023, 02:12 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Adding an Elephant Racing front sway bar to my teener. Found most all technical details and I've progressed to getting the bar thru holes drilled along with the sheet metal backers mounting fasteners to the fenders. Welding the backers in is next up.
Can't seem to find the location for the downlink U clip location on the A arm. Is there a location dimension ?? Also in what orientation are they. We'll be welding them in. Appreciate any help. |
mgphoto |
May 18 2023, 02:27 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
On page 56 of 97 you can see the attachment is just inside the rod bracing the control arm.
http://p914-6info.net/PDFs/Group%204%20Front%20Axle.pdf |
North Coast Jim |
May 18 2023, 02:51 PM
On page 56 of 97 you can see the attachment is just inside the rod bracing the control arm. http://p914-6info.net/PDFs/Group%204%20Front%20Axle.pdf Thank you very helpful |
Lo-Fi Version | Time is now: 17th May 2024 - 12:08 PM |
