Getting the pedals closer in line for foot work., Want to lower the brake pedal... |
peteinjp |
Jun 16 2023, 11:45 PM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Gotcha – thanks!
Actually, I think the modulation on the 21 mm master cylinder is pretty good. I’m not sure I want more travel than this but you’ve got me curious so I might have to try a 19 mm just to compare. Pete |
oakdalecurtis |
Jun 17 2023, 12:01 AM
Oakdalecurtis Group: Members Posts: 1,328 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I had a little different problem with my brake pedal. I have a 76 with the factory center console. Because the console limited my right foot placement, my size 13 feet didn’t fit on the gas pedal without dragging the right side of the brake pedal, not good. I ended up cutting the brake pedal off it’s arm and rewelding the pedal to the arm on the pedal’s right edge. I also welded a small triangular gusset from arm to pedal to keep it from bending under braking pressure. Net result is an additional inch of space for my big foot on the gas pedal, no more brake dragging…
peteinjp |
Jun 17 2023, 04:04 AM
Yeah- Momo console on my car. I’m sure I’d be hitting it if there were.
Pete |
BillJ |
Jun 17 2023, 05:42 AM
Senior Member Group: Members Posts: 1,106 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
You may want to consider simply a larger wider throttle pedal? That could help solve the brake getting in the way of your foot as well. Plenty of bolt on options out there that you could use from the track world.
Racer |
Jun 17 2023, 07:27 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
What about left foot braking? Then you don't have to adjust any pedals (IMG:style_emoticons/default/wink.gif)
BillJ |
Jun 17 2023, 07:21 PM
What about left foot braking? Then you don't have to adjust any pedals (IMG:style_emoticons/default/wink.gif) Doesnt work when you are shifting and need to work the clutch at the same time (IMG:style_emoticons/default/biggrin.gif) |
wonkipop |
Jun 18 2023, 04:40 AM
Advanced Member Group: Members Posts: 4,364 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
convert it to rhd.
you are in japan? why drive in the gutter when you don't have to. all your problems solved (but with some added new ones. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) ) no dead pedal for your clutch foot thats for sure. i forgot how i did this. is half a lifetime ago. but we frigged around with the loud pedal and its positioned further forward at its base of where it is left hand drive. i seem to remember we copied the crayfords car. its great for heel and toe. just right when you are really standing on the brake with the ball of your foot. (sorry for photo, dont really take photos with an iphone when i am going flat tilt into braking for a corner!). just never solved the old left foot problem, which is always a problem r h d. (cept in my lovely little renault clio with its thankfully unfrench moment of non arrogance and thoughtful provision of a dead pedal on the side of the centre console, very unfrench). what i am i saying. think i am saying find a new hinge point for loud pedal closer to the seat? i wish i could remember exactly what we did but its too long ago. i could get the pedal board off and photograph it but i am not sure its applicable to left hand drive. there is a few other things going on with my pedal cluster as its not a rhd 911 cluster for rhd, its the original 914 pedal cluster severely screwed with, as per crayfords. you can tell by the weird diagonal slash for the brake pedal lever. (IMG:style_emoticons/default/biggrin.gif) ignore that. ignore the gently massaged wheel well too. not enough to screw with 165 tyre clearance but enough to get the loud pedal the vital few centimeters right so i did not feel like a mongoloid driving on a diagonal with a surgically enhanced left leg to work the clutch. if you look close at the heel pad in the carpet you can see its a re-use of the original factory pad. just spot the indent for accelerator on extreme right hand side. gives you an idea of just how weirdly different the right hand problem is. (IMG:style_emoticons/default/biggrin.gif) but nothing to do with getting that angle on the loud pedal just right. |
Racer |
Jun 18 2023, 11:03 AM
What about left foot braking? Then you don't have to adjust any pedals (IMG:style_emoticons/default/wink.gif) Doesnt work when you are shifting and need to work the clutch at the same time (IMG:style_emoticons/default/biggrin.gif) Agreed, but the OP didn't mention heel/toe/downshiting, justst gas/brake transition. I don't have advice fir the OP how best to help. Someone else posted, learn to drive what you have. Adapt as needed. |
mlindner |
Jun 19 2023, 06:20 AM
Senior Member Group: Members Posts: 1,525 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
my brake pedal when braking is flush with the pas, perfect for heel and toe. Or in my case I just roll my foot over to burp the gas while down shifting. over 20 years doing this and the transmission loves it. Best, Mark
Lo-Fi Version | Time is now: 1st June 2024 - 12:26 AM |
