Ball Bearings for CV joints |
Literati914 |
May 23 2023, 08:45 AM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Has anyone ever tried sourcing just the ball bearings for our CV joints? I went thru the trouble of breaking a few extra cv joints down and cleaning everything up a few months ago, now just realized that I secured all parts in a dry place except the chrome ball bearings (IMG:style_emoticons/default/headbang.gif) . Needless to say they’ve been rained on several time and look terrible. Perhaps they can be cleaned, I’ll need to look into that (suggested methods ? ) - but assuming they’re scored or peeling chrome, are there any chances of purchasing these somewhere?
markhoward |
May 23 2023, 08:52 AM
Member Group: Members Posts: 375 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
I have some ball bearings from CV’s that are worn. I just did mine and had 2 sets of axles to work with so I chose the best 4 cv’s and have no use for the others. The balls seem fine but I did not look at them that closely. You can have them for shipping cost.
ogdougy |
May 23 2023, 09:05 AM
Newbie Group: Members Posts: 49 Joined: 9-May 22 From: Arizona Member No.: 26,536 Region Association: Southwest Region |
McMaster Carr is the easiest place to find stuff. But you're going to pay for it and will have way too many.
Mikey914 |
May 23 2023, 09:39 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Will be interesting to see how off the shelf bearings hold up. It was my understanding that these were hardened. I may be wrong.
930cabman |
May 23 2023, 10:36 AM
Advanced Member Group: Members Posts: 3,062 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Sounds like a time bomb to me. As far as I knew mixing any bearing parts is a big time no no. The precision and wear in involved with any bearing is very tight
markhoward |
May 23 2023, 04:11 PM
Sounds like a time bomb to me. As far as I knew mixing any bearing parts is a big time no no. The precision and wear in involved with any bearing is very tight Agree on that one. I think the diameter of the balls were not the same across different cv’s so did not mix up parts. |
mlindner |
May 23 2023, 07:04 PM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I just had a CV fail, if you want I'll send you the other three.
porschetub |
May 23 2023, 08:42 PM
Sounds like a time bomb to me. As far as I knew mixing any bearing parts is a big time no no. The precision and wear in involved with any bearing is very tight Agree on that one. I think the diameter of the balls were not the same across different cv’s so did not mix up parts. I think so also not worth risking IMO. |
Literati914 |
May 23 2023, 08:56 PM
Well it is a thing apparently, a little research led me to a few companies that sell specific ball bearings for CV joints, and yes there is a certain grade/type that’s specific to CV joint use. Here’s one place that’s interesting… with a 930 Porsche bearing replacement available:
https://www.kartek.com/parts/replacement-ty...dividually.html https://www.kartek.com/parts/replacement-po...dividually.html https://www.jbugs.com/SV/image/Type-4-CV-JOINT-Specs.jpg . |
Literati914 |
May 23 2023, 10:36 PM
False Alarm!! I’m an idiot sometimes.. the bearings I found out in the rain were the ones I’d actually panned out as not ideal. So they were the bad ones that I had and should have been thrown away, thought I did. So I got several complete sets to rebuild including a complete set of 108's too which I also forgot about - thanks everyone for your great (and typical) generosity!
Attached thumbnail(s) |
76-914 |
May 23 2023, 11:56 PM
You're not an idiot. Probably just a senior like most of us here. I can't remember half of the absent minded things I have done these past few years. (IMG:style_emoticons/default/headbang.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 03:13 AM |
