Spring sources, Who sells these special springs ? |
jim_hoyland |
May 24 2023, 08:53 AM
Get that VIN ? Group: Members Posts: 9,225 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
It’s the door latch spring with flat ends. Good spare.
The spring on the right is correct Who sells these ? Attached thumbnail(s) |
Root_Werks |
May 26 2023, 04:17 PM
Village Idiot Group: Members Posts: 8,288 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Is this the little spring on the inner lock mech?
bzettner |
May 26 2023, 04:21 PM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
If no vendors come up, I’d bet you could find something very similar at McMaster-Carr.
I assume length, diameter and wire diameter would get the “specs” really close to the original (IMG:style_emoticons/default/piratenanner.gif) |
Mikey914 |
May 26 2023, 06:09 PM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We have made some custom springs of all sizes. There just needs to be enough demand to pay for the set up and hopefully sell a few.
These may be commercially available. If not we could look at these. Mark |
jim_hoyland |
May 26 2023, 07:01 PM
The main feature are the flat ends. They hook over posts in the door latch…..
914Toy |
May 26 2023, 08:34 PM
Senior Member Group: Members Posts: 710 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
bdstone914 |
May 26 2023, 10:51 PM
bdstone914 Group: Members Posts: 4,497 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
It’s the door latch spring with flat ends. Good spare. The spring on the right is correct Who sells these ? Both are correct. There are two different lengths even though there is only one part number for the left or right doir latch. I have not been able to determine if it is anearly vs late issue. And the latches are different too as the mounting posts are different distances too. The same spring is used on VW beetle door latches. I doubt anyone makes them as there is no demand and it is a very special spring. Why do you need one? |
jim_hoyland |
May 27 2023, 06:32 PM
Right now I don’t need on, I just replaced the bad spring with a good spring I bought fro you years ago.
I was curious whether there is a source. Attached image(s) |
Lo-Fi Version | Time is now: 29th March 2024 - 08:22 AM |
