Yes, Brembo questions. Again. |
Tdskip |
May 25 2023, 07:21 AM
Good morning.
I managed to track down a couple pair of 3 inch caliper spacing Brembos. I started to do some initial fitment validation and realized that one pair fits perfectly on a vented front disk 3 inch caliper spacing whereas the other fits the same 3 inch caliper spacing perfectly but has too narrow of an opening where the disc goes so it’ll only work on unvented brake rotors. Any tips or coaching here on with the narrower pair will fit – is it simply a matter of needing an earlier non-vented from brake set up? In other words, one pair works fine with a 911 SC brake set up and I’m assuming the other pair should be fine with a non-vented 914 rotor? Thanks. |
Lo-Fi Version | Time is now: 8th May 2024 - 07:32 AM |
