Yes, Brembo questions. Again. |
Tdskip |
May 25 2023, 07:21 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning.
I managed to track down a couple pair of 3 inch caliper spacing Brembos. I started to do some initial fitment validation and realized that one pair fits perfectly on a vented front disk 3 inch caliper spacing whereas the other fits the same 3 inch caliper spacing perfectly but has too narrow of an opening where the disc goes so it’ll only work on unvented brake rotors. Any tips or coaching here on with the narrower pair will fit – is it simply a matter of needing an earlier non-vented from brake set up? In other words, one pair works fine with a 911 SC brake set up and I’m assuming the other pair should be fine with a non-vented 914 rotor? Thanks. |
eeyore |
May 25 2023, 10:35 AM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
I have stock early 911 solid rotors on my 5 lug conversion.
The 3" M calipers are the same left and right with a skinny spacer for solid rotors and a thicker spacer for vented rotors. get another thin or fat spacer depending on which rotor you want. |
Lo-Fi Version | Time is now: 8th May 2024 - 04:22 AM |
