Yes, Brembo questions. Again. |
Tdskip |
May 25 2023, 07:21 AM
Good morning.
I managed to track down a couple pair of 3 inch caliper spacing Brembos. I started to do some initial fitment validation and realized that one pair fits perfectly on a vented front disk 3 inch caliper spacing whereas the other fits the same 3 inch caliper spacing perfectly but has too narrow of an opening where the disc goes so it’ll only work on unvented brake rotors. Any tips or coaching here on with the narrower pair will fit – is it simply a matter of needing an earlier non-vented from brake set up? In other words, one pair works fine with a 911 SC brake set up and I’m assuming the other pair should be fine with a non-vented 914 rotor? Thanks. |
Literati914 |
Jun 1 2023, 09:52 AM
Senior Member Group: Members Posts: 1,459 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
As a first step, contact the person you got the non-spacer pair from… ask him if he may have removed the spacers at some point and if he still has them and the bolts stashed away somewhere.
Btw, if I’m not mistaken, the non-spacer pair would only work with the early stock /4 struts and not the later ones.. someone correct me if that’s wrong. . |
mepstein |
Jun 1 2023, 11:13 AM
914-6 GT in waiting Group: Members Posts: 19,257 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
As a first step, contact the person you got the non-spacer pair from… ask him if he may have removed the spacers at some point and if he still has them and the bolts stashed away somewhere. Btw, if I’m not mistaken, the non-spacer pair would only work with the early stock /4 struts and not the later ones.. someone correct me if that’s wrong. . Maybe for a 3” solid rotor like a 912 |
Lo-Fi Version | Time is now: 8th May 2024 - 04:07 PM |
