WTB Body Parts, Lower driver footwell, and back half drivers rear fender |
zoomCat |
May 26 2023, 01:02 PM
Member Group: Members Posts: 160 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
As restoration continues we continue to find more, uh, stuff. Now its some old repairs that we need to make right.
I'm looking for the section near where the master cylinder mounts, and the back half of the rear drivers side fender. I don't think these are specific to year. Ideally near the Cincinnati-Dayton area but that's not likely. Let me know what you've got, or who might have them. |
partwerks |
May 26 2023, 10:15 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
PM sent.
Montreal914 |
May 28 2023, 11:17 AM
Senior Member Group: Members Posts: 1,543 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
zoomCat |
May 28 2023, 12:13 PM
cgnj |
May 28 2023, 07:22 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
@motreal914
How many drill bits and how long did it take? |
cgnj |
May 28 2023, 07:23 PM
@motreal914
Montreal914 |
May 28 2023, 07:57 PM
I have this... Very small dent sharpie circled. Located in SoCal. This looks promising. Do you know exactly where the cut was made along the top? How far from the gasket channel edge? Using a thin disk on my 4" angle grinder, I cut along the vertical edge to use the gasket channel. My donor fender was missing it (IMG:style_emoticons/default/dry.gif). Pretty detailed operation on my build thread, especially post #87. http://www.914world.com/bbs2/index.php?s=&...t&p=3043001 The part is dirty in the picture but it is actually a good piece. I had a similar situation but elected to replace the whole fender. I am not a good welder and don't use TIG, so I wasn't pleased with the idea of having welds to deal with in bodywork. Let me know if you have other questions. (IMG:style_emoticons/default/beerchug.gif) |
Montreal914 |
May 28 2023, 08:04 PM
@motreal914 How many drill bits and how long did it take? @cgnj Well, I got the fender piece pretty much of that size. It had the gasket channel and the inner fender part spot welded to it, including the tailight area. So I probably had about 20 spot welds to drill in the gasket area, then the ones in the taillight area. The most difficult area is the tailing obviously. I also used a thin grinding disk on a Dremel. One drill bit was needed, but since then I have been using one of those end mill type 5/16" spot weld drill bit. It takes a lot of time to do delicate work. I am not doing this for someone or for money, therefore I like to take my time and do it up to my satisfaction. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 1st May 2024 - 04:05 PM |
