Free: Two Cases of 0-40 Mobil 1 Oil, No Longer Needed |
914_teener |
May 28 2023, 11:32 AM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Since I sold the Cayman no longer needed and cleaning out the garage.
Can deliver local in San Gabriel Valley or close by to San Dimas area. Rob |
technicalninja |
May 29 2023, 09:41 AM
Senior Member Group: Members Posts: 1,230 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
The viscosity of that oil at operating temp (100C) is 40.
The 0W is the viscosity at 0 degrees Celsius and that's not really correct. It reacts similar to a 0 w due to additives that make it flow better at cold temps. Personally, I'm not planning on firing or driving my 914 below freezing. I see that as a 40w oil and would have no issues using it in almost anything that doesn't suggest a 0w/20 or 0w/16 (new stuff). The whole multi-weight labels are a marketing ploy IMO. I believe the standard viscosity test for automotive oils happens at 100C This is from SAE J300. The first number with a W behind it is a calculated number and has to be taken as such. Now, I wouldn't hammer the crap out of the 914 with that oil in it from dead cold. I'd let it warm up to temp before spirited driving, but I'd do that anyway on any car with any oil. My preferred oil for a 914 is the new Castrol GTX "Classic" that another member on here made me aware of. I ordered two 5 qt containers minutes after reading that post. If I could get the M1 Euro at 20w/50 that would be my oil of choice. |
VolksSled |
May 29 2023, 10:22 AM
Newbie Group: Members Posts: 28 Joined: 3-May 23 From: California Member No.: 27,331 Region Association: Southern California |
The viscosity of that oil at operating temp (100C) is 40. The 0W is the viscosity at 0 degrees Celsius and that's not really correct. It reacts similar to a 0 w due to additives that make it flow better at cold temps. Personally, I'm not planning on firing or driving my 914 below freezing. I see that as a 40w oil and would have no issues using it in almost anything that doesn't suggest a 0w/20 or 0w/16 (new stuff). The whole multi-weight labels are a marketing ploy IMO. I believe the standard viscosity test for automotive oils happens at 100C This is from SAE J300. The first number with a W behind it is a calculated number and has to be taken as such. Now, I wouldn't hammer the crap out of the 914 with that oil in it from dead cold. I'd let it warm up to temp before spirited driving, but I'd do that anyway on any car with any oil. My preferred oil for a 914 is the new Castrol GTX "Classic" that another member on here made me aware of. I ordered two 5 qt containers minutes after reading that post. If I could get the M1 Euro at 20w/50 that would be my oil of choice. I wouldn’t say preferred but having acceess to the Castrol just in case is convenient for several applications Oil of choice I was told by my ( Volkswagen bus ) mechanic is gonna be brad penn ( for 914/ s ) not the bus’s “ cause it cost to much “ |
Lo-Fi Version | Time is now: 18th May 2024 - 07:40 PM |
