Replaced Fuel Pump, Replacement Pump Run Backwards |
jrrobertson |
May 28 2023, 07:35 PM
Newbie Group: Members Posts: 27 Joined: 28-December 16 From: Wolverine Lake , Michigan Member No.: 20,704 Region Association: Upper MidWest |
The fuel pump (0580 463 009) on my 71 quit working. Even with power connected directly to the pump it did not work. I replaced it with a spare pump (0580 463 005) I had. This one only builds pressure if I switch the positive and negative leads. It will run when connected normally but it will run backwards and will push fuel down the return line. Anyone have any ideas as to why this is? The car runs OK with the wires switched.
The car has the original D-jet fuel injection system. |
windforfun |
May 28 2023, 07:39 PM
Senior Member Group: Members Posts: 1,789 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Why is the part number different? Is that a 914 pump? AA doesn't recognize either PN for a 914. Post some pics of the pumps.
Lo-Fi Version | Time is now: 17th May 2024 - 05:20 AM |
