A couple /6 conversion Q's |
930cabman |
Jun 10 2023, 11:08 AM
Advanced Member Group: Members Posts: 3,062 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Wrapping up a couple patches in the battery/hell hole area, getting things ready to mount a new Maddog OEM style engine mount. It looks as though the main wiring harness will interfere with the new engine mount. Is it as simple as moving the harness towards the passenger side an inch or so?
Also, should I remove the /4 crossbar mounts? My gut says yes, get them out of the way Is cutting a hole in the firewall required to access the fan belt? TIA to all |
Jun 10 2023, 11:21 AM
Resident German Group: Admin Posts: 41,637 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Wrapping up a couple patches in the battery/hell hole area, getting things ready to mount a new Maddog OEM style engine mount. It looks as though the main wiring harness will interfere with the new engine mount. Is it as simple as moving the harness towards the passenger side an inch or so? Also, should I remove the /4 crossbar mounts? My gut says yes, get them out of the way Is cutting a hole in the firewall required to access the fan belt? Yes Optional No |
Cairo94507 |
Jun 10 2023, 12:24 PM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
1. Yes
2. definitely 3. I would not cut an original 6 chassis for fan belt access, but a conversion chassis, maybe. (IMG:style_emoticons/default/beerchug.gif) |
Jun 10 2023, 01:00 PM
One good reason to remove the 914-4 engines me mounts is because there is often rust behind the mounts, especially on the passenger side. I’ve removed them on my rusty tub and left them on the non rusty car. Works either way.
930cabman |
Jun 11 2023, 11:20 AM
Thanks to all who replied. I have been researching this project for some time, but confirmation is always good.
Had a few hours this morning, wife out of town. The passenger side engine shelf was damaged from rust and prior impact so had been previously removed. Having access to the /4 engine mount made removal somewhat straightforward. Drivers side engine shelf is in great condition, but will need a bit of selective demo to access the engine mount. Is the only reason some guys cut out the firewall is for fan belt access? how did the factory allow for belt replacement/adjustment on the original /6 cars? |
Jun 11 2023, 11:28 AM
Drop the motor or for some people with good dexterity, do it in place. I have seem pictures of a 90 degree bent box wrench to help with removing the fan nut
brant |
Jun 11 2023, 12:31 PM
The belt can be changed in car but its not fun
You can not drive a 911 without a belt. Even a little bit will cook the engine In my race car I have lost belts more than a few times Would not want to do that replacement on the rush without the access Attached image(s) |
targa72e |
Jun 11 2023, 11:13 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
Adding my thoughts having used a Mad Dog mount on my conversion.
#1 yes. Everything fit fine #2 I removed mine and thin put back a reinforcement piece of sheet metal. Some said it helped reinforce the area. #3 the access to the fan area is very limited. My conversion does not have a access port. If I needed to replace the belt I would probably pull the engine. I would estimate a belt replacement for me in my garage at 5 hours. This would be pull engine, replace belt and reinstall. I am starting another -6 conversion and plan on putting in a access panel. john |
mlindner |
Jun 12 2023, 05:09 AM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
ClayPerrine |
Jun 12 2023, 06:19 AM
I vehemently disagree in the idea of cutting a hole in something called a "FIREWALL".
Having lived through an engine fire, it will not happen on my cars. The factory didn't put one in, so I am not either. The belt can be changed in the car. It is not easy, but it can be done. And it all else fails, roll the new belt on, then drive it home and drop the motor to replace it properly. With how easy it is to drop the motor, I do it just to adjust the valves. So while it is out, I put a new fan belt on, even if it doesn't need it. |
Jun 12 2023, 06:33 AM
Looks like most people screw on a plate to cover the hole. If the vehicle catches on fire, exit the vehicle.
ClayPerrine |
Jun 12 2023, 07:03 AM
mlindner |
Jun 12 2023, 07:39 AM
If a fire starts in a 914 four or six, at speed or stationary. Being that the engine is right behind you that rear window is going to go before anything regarding fire wall. And Clay I understand your concern, but a lot of 914 enthusiast do not have the tools or skill to pull engines that offten for service as you do. I greatly appreciate everything you bring to this forum Clay. Best, Mark
sixaddict |
Jun 12 2023, 07:58 AM
Senior Member Group: Members Posts: 801 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Lots of competent advice…..but would not do without in track car .
Attached thumbnail(s) |
Root_Werks |
Jun 12 2023, 08:42 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Wrapping up a couple patches in the battery/hell hole area, getting things ready to mount a new Maddog OEM style engine mount. It looks as though the main wiring harness will interfere with the new engine mount. Is it as simple as moving the harness towards the passenger side an inch or so? Also, should I remove the /4 crossbar mounts? My gut says yes, get them out of the way Is cutting a hole in the firewall required to access the fan belt? Yes Optional No (IMG:style_emoticons/default/agree.gif) |
dr914@autoatlanta.com |
Jun 12 2023, 09:15 AM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
do not cut the firewall!!!!!! DO remove the four cylinder mounting pods CAREFULLY and immediately sell the right one on e bay for 450!!!
Wrapping up a couple patches in the battery/hell hole area, getting things ready to mount a new Maddog OEM style engine mount. It looks as though the main wiring harness will interfere with the new engine mount. Is it as simple as moving the harness towards the passenger side an inch or so? Also, should I remove the /4 crossbar mounts? My gut says yes, get them out of the way Is cutting a hole in the firewall required to access the fan belt? TIA to all |
Jun 12 2023, 09:23 AM
do not cut the firewall!!!!!! DO remove the four cylinder mounting pods CAREFULLY and immediately sell the right one on e bay for 450!!! Wrapping up a couple patches in the battery/hell hole area, getting things ready to mount a new Maddog OEM style engine mount. It looks as though the main wiring harness will interfere with the new engine mount. Is it as simple as moving the harness towards the passenger side an inch or so? Also, should I remove the /4 crossbar mounts? My gut says yes, get them out of the way Is cutting a hole in the firewall required to access the fan belt? TIA to all I gave mine away to another member here. I think Dion did the same. |
930cabman |
Jun 12 2023, 09:30 AM
do not cut the firewall!!!!!! DO remove the four cylinder mounting pods CAREFULLY and immediately sell the right one on e bay for 450!!! Wrapping up a couple patches in the battery/hell hole area, getting things ready to mount a new Maddog OEM style engine mount. It looks as though the main wiring harness will interfere with the new engine mount. Is it as simple as moving the harness towards the passenger side an inch or so? Also, should I remove the /4 crossbar mounts? My gut says yes, get them out of the way Is cutting a hole in the firewall required to access the fan belt? TIA to all Thanks again to all repliees (if that's a word) I have removed the passenger side /4 engine mount and it's in perfect condition, with a minimum of rusting underneath. Have yet to go after the drivers side, it's concealed by the engine shelf. I will probably be opening up the firewall for fan belt access, as my gut and the advice of others tells me. Also, it appears as though the brake compensator needs to be moved when using the Maddog OEM style mount. This is not a bolt in conversion for sure, but I am hoping the result will be worth it. I have not driven or ridden in a 914/6, so this will be a surprise. |
Jun 12 2023, 10:07 AM
The brake compensator was different in early vs late so some cars need modification. It will be worth it. A 914 with a six is a blast. (IMG:style_emoticons/default/driving.gif)
Jun 12 2023, 10:21 AM
can someone with a six show how hard it is to get in there to change the belt?
I was looking at the /4 the other day...and that is no walk in the park. I recall this car is all about closing your eyes and doing the work purely based upon touch. Can you fit all the required tools in to properly change a belt on a six...without ever having to drop the motor? Rich |
Lo-Fi Version | Time is now: 15th May 2024 - 06:06 PM |
