A couple /6 conversion Q's |
Jun 12 2023, 10:40 AM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
can someone with a six show how hard it is to get in there to change the belt? I was looking at the /4 the other day...and that is no walk in the park. I recall this car is all about closing your eyes and doing the work purely based upon touch. Can you fit all the required tools in to properly change a belt on a six...without ever having to drop the motor? Rich Yes but it’s not fun. One of our guys did it a couple months ago but he’s 22 years old and does whatever you tell him to do. It’s not something I would want to do myself. I did tell him to remove the engine lid and he said that helped. |
Jun 12 2023, 10:42 AM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
can someone with a six show how hard it is to get in there to change the belt? I was looking at the /4 the other day...and that is no walk in the park. I recall this car is all about closing your eyes and doing the work purely based upon touch. Can you fit all the required tools in to properly change a belt on a six...without ever having to drop the motor? Rich Yes but it’s not fun. One of our guys did it a couple months ago but he’s 22 years old and does whatever you tell him to do. It’s not something I would want to do myself. I did tell him to remove the engine lid and he said that helped. So, this is a February annual project...drop motor, do everything needed for the season. rich |
campbellcj |
Jun 12 2023, 10:47 AM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I've done the belt with no firewall access hole and can vouch for it being a beotch - you're essentially working by feel unless you maybe have a helper hold a mirror or camera. My car has a removable lid and no airbox to pull off or work around which does help. I have literally injured myself several times working on this car lol.
930cabman |
Jun 12 2023, 12:26 PM
Advanced Member Group: Members Posts: 3,109 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I will definately be opening up the firewall to provide fan belt access, thanks for the comments. I am also sure the opening can be made reasonably fire resistant and allow for access into the engine compartment. Working on a mid engined car is tough enough without making it more difficult. Can anyone provide an approx. size?
Every so often an engine drop to check things out is a good practice, but somewhere out in the middle of nowhere to change a fan belt. No way |
Jun 12 2023, 12:42 PM
If you want the firewall piece, I have one from a parts car. $50 + ship.
930cabman |
Jun 12 2023, 12:49 PM
Justinp71 |
Jun 12 2023, 01:22 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Removing the engine mounts does make for a cleaner look, only reason to keep is if you have future thoughts of a different motor install. LS and most other engine swaps use them. Once you go six though you just want to make it bigger... (IMG:style_emoticons/default/smile.gif).
I did have to remove the rear brake (anti lock?) valve when I installed the Rich Johnson mount. |
930cabman |
Jun 12 2023, 04:21 PM
Removing the engine mounts does make for a cleaner look, only reason to keep is if you have future thoughts of a different motor install. LS and most other engine swaps use them. Once you go six though you just want to make it bigger... (IMG:style_emoticons/default/smile.gif). I did have to remove the rear brake (anti lock?) valve when I installed the Rich Johnson mount. I have a fresh 2.7 on the shelf scheduled to go in hopefully soon. If anything I would hop up the 2.7 or increase power some other way. I would probably not go an LS Considering either Webers or CIS, Webers will probably get the nod, need to look at the throttle shafts soon |
Jun 12 2023, 05:31 PM
If you want the firewall piece, I have one from a parts car. $50 + ship. Can you post a photo? is it a bolt on? sounds like an easy button thanks It’s just the cut out firewall center section. I’ll dig it up and post a pic. The advantage over a piece of sheet steel is it follows the curves of the firewall. |
rgalla9146 |
Jun 12 2023, 07:04 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If you want the firewall piece, I have one from a parts car. $50 + ship. Can you post a photo? is it a bolt on? sounds like an easy button thanks It’s just the cut out firewall center section. I’ll dig it up and post a pic. The advantage over a piece of sheet steel is it follows the curves of the firewall. (IMG:style_emoticons/default/agree.gif) with a piece cut from a scrap car the fit is instant and perfect. leave at least a a 3/4" overlap and secure with four fasteners...or more if you go large. Weld nuts or palnuts on engine side of firewall Attached thumbnail(s) |
930cabman |
Jun 13 2023, 04:55 AM
If you want the firewall piece, I have one from a parts car. $50 + ship. Can you post a photo? is it a bolt on? sounds like an easy button thanks It’s just the cut out firewall center section. I’ll dig it up and post a pic. The advantage over a piece of sheet steel is it follows the curves of the firewall. (IMG:style_emoticons/default/agree.gif) with a piece cut from a scrap car the fit is instant and perfect. leave at least a a 3/4" overlap and secure with four fasteners...or more if you go large. Weld nuts or palnuts on engine side of firewall I like the look of the painted firewall, how is the engine noise? |
rgalla9146 |
Jun 13 2023, 05:24 AM
Plenty. Haven't found a simple effective solution. I'm considering the rubbery asphalt mat that was used in early cars covered with form fitting perlon. I don't want anything 'fancy' |
Jun 13 2023, 06:20 AM
Plenty. Haven't found a simple effective solution. I'm considering the rubbery asphalt mat that was used in early cars covered with form fitting perlon. I don't want anything 'fancy' Rory - Look at “Lizard Skin”. Great product. Easy to apply. Very effective. Can be painted over. |
ConeDodger |
Jun 13 2023, 07:13 AM
Apex killer! Group: Members Posts: 23,602 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
can someone with a six show how hard it is to get in there to change the belt? I was looking at the /4 the other day...and that is no walk in the park. I recall this car is all about closing your eyes and doing the work purely based upon touch. Can you fit all the required tools in to properly change a belt on a six...without ever having to drop the motor? Rich It’s easy to change the belt. You drop the motor. (IMG:style_emoticons/default/happy11.gif) No holes will ever be cut in my firewall while my name is on the title. I remember a phone call from McMark asking about the four mounts. My response to his question “do you see yourself ever going back to a four cylinder?” Was “Remove the mounts Mark!” |
ClayPerrine |
Jun 13 2023, 07:26 AM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It’s easy to change the belt. You drop the motor. (IMG:style_emoticons/default/happy11.gif) No holes will ever be cut in my firewall while my name is on the title. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) 1000% |
Justinp71 |
Jun 13 2023, 01:15 PM
Removing the engine mounts does make for a cleaner look, only reason to keep is if you have future thoughts of a different motor install. LS and most other engine swaps use them. Once you go six though you just want to make it bigger... (IMG:style_emoticons/default/smile.gif). I did have to remove the rear brake (anti lock?) valve when I installed the Rich Johnson mount. I have a fresh 2.7 on the shelf scheduled to go in hopefully soon. If anything I would hop up the 2.7 or increase power some other way. I would probably not go an LS Considering either Webers or CIS, Webers will probably get the nod, need to look at the throttle shafts soon Originally I went from a tired 2.7CIS to a 3.0 with Webers, headers and mild cam (DC20 I think). Big difference in power and overall responsiveness. Carbs can be a little stinky in general though. I added breather recirculation which helps. |
Root_Werks |
Jun 13 2023, 02:20 PM
Village Idiot Group: Members Posts: 8,326 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
If you already have a fresh 2.7:
Drop in Solex cams if you plan to use carbs Drop in 964 cams if you plan to use CIS Or sell it and buy a higher HP engine. (IMG:style_emoticons/default/driving.gif) |
930cabman |
Jun 13 2023, 03:49 PM
If you already have a fresh 2.7: Drop in Solex cams if you plan to use carbs Drop in 964 cams if you plan to use CIS Or sell it and buy a higher HP engine. (IMG:style_emoticons/default/driving.gif) Yes, my engine builder suggested the Solex cams. She is fresh and I can't wait to fire her up for the first time. I have a set of 40 IDTP carbs on the shelf, but need to go through them |
930cabman |
Jun 15 2023, 08:49 AM
Using the Maddog OEM style engine mount requires the brake regulator to be moved an inch or so to the West. Where is a good source for metric brake lines and fittings? Are they the same/similar to domestic "double flare"?
brant |
Jun 15 2023, 09:07 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I believe the correct flare is different
Called a bubble flair |
Lo-Fi Version | Time is now: 29th May 2024 - 05:17 AM |
