A couple /6 conversion Q's |
Root_Werks |
Jun 15 2023, 10:26 AM
Village Idiot Group: Members Posts: 8,326 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
If you already have a fresh 2.7: Drop in Solex cams if you plan to use carbs Drop in 964 cams if you plan to use CIS Or sell it and buy a higher HP engine. (IMG:style_emoticons/default/driving.gif) Yes, my engine builder suggested the Solex cams. She is fresh and I can't wait to fire her up for the first time. I have a set of 40 IDTP carbs on the shelf, but need to go through them That would be a sweet combo. |
nditiz1 |
Jun 16 2023, 07:10 PM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
@930cabman
Check out my build thread as I went through similar issues you are facing. I converted my proportioning valve to an early style setup, and made a custom line to go through the firewall. I used a bungie cord to pull the wiring harness out of the way while welding the maddog mount. |
930cabman |
Jun 17 2023, 05:10 AM
Advanced Member Group: Members Posts: 3,109 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
@930cabman Check out my build thread as I went through similar issues you are facing. I converted my proportioning valve to an early style setup, and made a custom line to go through the firewall. I used a bungie cord to pull the wiring harness out of the way while welding the maddog mount. Thanks, I see nothing unsurmountable, just a couple kinks in the road. Speaking of kinks how about the brake line going through the firewall!!! I will try to use the original proportioning valve if possible. |
mlindner |
Jun 18 2023, 05:13 AM
Senior Member Group: Members Posts: 1,524 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
All Porsche Boxster ane Cayman's have service covers in firewall for belt replacement and water pump replacement. Mark
Lo-Fi Version | Time is now: 29th May 2024 - 05:59 AM |
