Fouled Plugs, Uneven fuel amounts from injectors |
mdart |
Aug 15 2005, 06:01 PM
Newbie Group: Members Posts: 2 Joined: 15-August 05 From: so oregon Member No.: 4,594 |
I just acquired a 914 with a 1.7 engine. It runs great until two of the plugs foul. I removed both injectors from one side of the motor (one cylinder was fouling, the other was OK) when I cranked the motor the injector that had been fouling the plug was spraying about twice the gas that the other injector was. When I switched the connectors, the other injector was now spraying twice the amount. The only other bit of info I have is that the previous owner installed a Pertronics ignition in the car..
goose2 |
Aug 15 2005, 06:32 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
Are the two plugs that are fouling located diagonally opposite each other? If so, sounds like your trigger points are bad.
mdart |
Aug 15 2005, 08:02 PM
Number 2 and 3 cylinder spark plugs are fouling.
Aug 15 2005, 08:24 PM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
pull out the trigger points and clean them, and clean out inside the dizzy where they reside.
Try it again. There are alot of tests on Djet here if you do a search. Rich |
Lo-Fi Version | Time is now: 4th May 2024 - 11:32 PM |
