Adding to the Wiring Harness, I could use recommendations |
Literati914 |
Jul 15 2023, 11:57 PM
Senior Member Group: Members Posts: 1,462 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Just trying to think ahead - I’d like to add some extra wiring to my original ‘72 wiring harness before I re-install it into the car. I always struggle with electrical stuff but usually manage eventually.. but I was hoping for some recommendations to try and eliminate any “ooops!” moments later.
Im gonna have to figure out stuff like preferred gauge of wire, inline fuse/relays, is a ground wire needed thru the harness for particular items, etc. 1. A/F Lambda sensor: both a + & - wire needed thru the harness?..where should it ground?..what gauge wire? 2. 3rd brake light: same questions ^ , also can I just tap into the already present stock wire for rear brakes? 3. Oil pressure numerical (for combo gauge), I’ll be using a dual pole sender at the engine: same questions^ and where does it ground? 4. CHT: so I think I’ll only be adding the specialized braided wire to the harness - is that right? Does a ground wire come in to play somewhere? 5. Fog lights: I need to look closer at my original harness (‘72) but I don’t think the car came with fogs originally. So same questions as above ^ . 6. Positive Battery Cable: so, rather than have a bunch of wires attached outside the + battery terminal , I’d like to get them imbedded inside the harness and shrink wrapped into the + cable’s outer shell. I believe the radio is usually one that you see here (what gauge?)… and what are some of the other stuff we usually see attached to the + side (IMG:style_emoticons/default/confused24.gif) Any help appreciated! . |
Lo-Fi Version | Time is now: 19th May 2024 - 05:50 PM |
