Leaking oil, pump |
Leaking oil, pump |
930cabman |
Jul 16 2023, 05:15 PM
Advanced Member Group: Members Posts: 3,066 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Fresh 2056 (2022) engine is running well, but a pesky oil leak has been a down side from day one. Need to be careful if parking at a friends (or enemies) driveway. I don't have 100% cure, but I have isolated it to the front seal/oil pump area over the past couple weeks. I was determined to find it this weekend and removed the engine bar, propped the engine up with a 4x4 and warmed her up good. It took awhile (170 ish oil temp) to get a leak going, but the studs/nuts holding the oil pump cover were leaking. The front seal area looks great, the gasket(s) between the oil pump/case and oil pump/cover look good also. Hopefully new sealing washers and sealing nuts will get things dried up.
Lo-Fi Version | Time is now: 19th May 2024 - 09:22 PM |
