Valve access with 75-76 exhaust system, Valve access with 75-76 exhaust system |
pistonboy |
Jul 17 2023, 02:03 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
I have a 1974 vehicle with a 75-76 exhaust system. Is it necessary to remove the heat exchangers to gain access to the valves for adjustment? It appears this way. How is it done? Is it necessary to remove the heat exchangers? Thank you. |
TheCabinetmaker |
Jul 18 2023, 10:30 AM
No need to remove exchangers. It can be done with it intact. Takes a little finesse.
dr914@autoatlanta.com |
Jul 18 2023, 11:31 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the key is a very long feeler gauge: something that looks like this:
http://www.autoatlanta.com/Porsche-Feeler-...PN-RTL1060.html Hello I have a 1974 vehicle with a 75-76 exhaust system. Is it necessary to remove the heat exchangers to gain access to the valves for adjustment? It appears this way. How is it done? Is it necessary to remove the heat exchangers? Thank you. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:12 PM |
