Brakes, Do 914's really stop! |
Petepat |
Jul 25 2023, 02:22 PM
Member Group: Members Posts: 58 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None |
The brakes on my 914 are useless, the master cylinder was leaking so I have replaced it and bleed the brakes..........and they are still useless although not spongy. I understand these cars are not servo-assisted like modern cars but it doesn't matter how hard I press the brake pedal the wheels never ever lock. Am I expecting too much?
Van B |
Jul 25 2023, 02:25 PM
Senior Member Group: Members Posts: 1,583 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
they should lock. are you new to the car?
DRPHIL914 |
Jul 25 2023, 02:28 PM
Yes, they do so you should be able to lock them up so if you cant, and the pedal is still soft you have 2 issues most likely, one is that its not full bled out, there is air in the system, sometimes its trapped by the rear proportioning valve , or just in the calipers.
and 2. you may be needing to set the venting clearance on the rear pads, they are not self adjusting like in the front. a power bleeder like a Motiv might be helpful or the bleeder screws that dont require you to be opening and closing them with every pump of the pedal. Phil |
DRPHIL914 |
sorry for got to add this... (IMG:style_emoticons/default/welcome.png) |
davep |
Jul 25 2023, 02:49 PM
Most of the time you do not want to lock up the brakes as then you tend to lose control of the car. Obviously you lock up the brakes when you come to a stop.
For maximum stopping capacity you need the pistons to be free, not binding in their bores, so a caliper rebuild is a sure means to achieve this. New or freshly machined rotor surfaces will provide maximum surface area and a suitable friction surface; glazed surfaces and/or rusted rotors are not going to provide a suitable friction surface. Brake pads must not bind in the calipers, must provide the high coefficient of friction and must not be glazed. Pads, Pistons & Rotors; it is all in the combo. |
brant |
Jul 25 2023, 03:00 PM
Sometimes old brake lines can be spongy
Use good pads also…. Not the old ones that are in the car But bleeding is the most likely |
Jul 25 2023, 03:34 PM
4 wheel disk brakes, 2100 lb car.
It stops fast Replace all flexible brake lines. New master if needed New pads You will be surprised how well it stops |
Jul 25 2023, 03:37 PM
And you might want to review this site and get some advice from the brake guru https://pmbperformance.com/ |
emerygt350 |
Jul 25 2023, 03:46 PM
Advanced Member Group: Members Posts: 2,096 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
As someone that just took his 914 to Watkins glen and headed into turn 1 at 90 miles per hour, let me tell you, they work. By the end of day two I wasn't hitting the brakes till 200 feet. Before the bus stop I was waiting till 100 feet (but I was taking that corner at much higher speeds).
My fronts are untouched, the rears are PMB rebuilt. All stock. I did put braided hoses on it. Safety and all that. I also have strong legs and I am 6' "1. You have to really give the brakes a push though. |
Van B |
Jul 25 2023, 03:59 PM
I also have strong legs and I am 6' "1. Emery… you trying to get back in the dating game? (IMG:style_emoticons/default/bootyshake.gif) |
rfinegan |
Jul 25 2023, 04:22 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
When working correctly they will stop on a Dime...and give you 5 cents change!!
They work well...IT took a while to get mine right. but stoping well now |
Jul 25 2023, 05:34 PM
Rule of thumb is to replace soft lines if you don’t know when they were last replaced. They swell shut and don’t allow fluid to flow.
davep |
Jul 25 2023, 05:54 PM
Years ago I did a session at Watkin Glen, then headed down into town on that long hill. That was possibly the only time I had brake fade. The next year I had the 911S "A" calipers with vented rotors and no more fade.
Karl R |
Jul 25 2023, 06:38 PM
Newbie Group: Members Posts: 33 Joined: 25-July 23 From: honolulu Member No.: 27,486 Region Association: Southern California |
I've been away from the 914 for decades and just coming back. Might be things have changed, but if your pedal feels good but the car feels like is just gonna keep rolling, you might try different pads. What always worked best for me was the cheapest ones: full organic. Not metallic or ceramic or semi metallic, but full organic. Not good for racing and they make a mess, but they grab the rotor better.
steuspeed |
Jul 25 2023, 06:43 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Air in the lines somewhere. Crack the line at the proportioning valve. Bleed from the right rear first. Bleed from the upper valve if you have dual valves. Add a length of hose so it's end is higher than the fender. Bubbles rise.
bkrantz |
Jul 25 2023, 06:51 PM
914 Guru Group: Members Posts: 7,762 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Yes, they do so you should be able to lock them up so if you cant, and the pedal is still soft you have 2 issues most likely, one is that its not full bled out, there is air in the system, sometimes its trapped by the rear proportioning valve , or just in the calipers. and 2. you may be needing to set the venting clearance on the rear pads, they are not self adjusting like in the front. a power bleeder like a Motiv might be helpful or the bleeder screws that dont require you to be opening and closing them with every pump of the pedal. Phil Let me add #3, which was important for getting good braking in my car:making sure the master cylinder mount is solid, and if necessary, making a brace so the MC does not move when pushing hard on the pedal. |
theer |
Jul 25 2023, 10:33 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I agree with the others. I can easily lock up the wheels. I have the 19mm master cylinder (17mm was stock), so the pedal is fairly stiff, but a good stomp on the pedal is all it takes. The bigger the master the harder the pedal will be. I never worry about whether the brakes will work… they always do. Even if the rears are non-functioning, the fronts alone are more than adequate to stop the car quickly. Not recommended, of course! I’ll second the idea that rubber flex lines may have swelled. Happened to me on my Karmann Ghia. Good luck! |
Porschef |
Jul 26 2023, 06:59 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
I've been away from the 914 for decades and just coming back. Might be things have changed, but if your pedal feels good but the car feels like is just gonna keep rolling, you might try different pads. What always worked best for me was the cheapest ones: full organic. Not metallic or ceramic or semi metallic, but full organic. Not good for racing and they make a mess, but they grab the rotor better. (IMG:style_emoticons/default/welcome.png) This is what I’m thinking, the pads I’m running are probably more meant for track work. I’d imagine you deal with some hills... (IMG:style_emoticons/default/smile.gif) |
Petepat |
Jul 26 2023, 08:08 AM
I've been away from the 914 for decades and just coming back. Might be things have changed, but if your pedal feels good but the car feels like is just gonna keep rolling, you might try different pads. What always worked best for me was the cheapest ones: full organic. Not metallic or ceramic or semi metallic, but full organic. Not good for racing and they make a mess, but they grab the rotor better. (IMG:style_emoticons/default/welcome.png) This is what I’m thinking, the pads I’m running are probably more meant for track work. I’d imagine you deal with some hills... (IMG:style_emoticons/default/smile.gif) OK thanks guys, so now I know that a 914 does actually stop it's back to the drawing board with some of your suggestions. Cheers. |
VaccaRabite |
Jul 26 2023, 08:26 AM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
OK thanks guys, so now I know that a 914 does actually stop it's back to the drawing board with some of your suggestions. Cheers. So give us an idea of what you have on the car. I'd use Porterfield pads, either stock rubber or PMB braided stainless flex lines. If your 17mm master is not leaking, use it. I moved to a 19mm as a new 17mm is either very expensive or unobtainium depending on when you look. 17mm uses less leg effort and more pedal travel but stops the car WELL. 19mm will use less pedal travel and more leg effort to stop the car EXACTLY THE SAME AS THE 17MM. Try a Motive power bleeder to get the calipers bled. It helps! Do not remove the proportioning valve. This was common back in the 80-90s and there are still some people that swear by it. I've seen the wreckage that results from the rears locking before the fronts first hand. When you get it dialed in, the 914 STOPS. Zach |
Lo-Fi Version | Time is now: 15th May 2024 - 01:44 PM |
