Brakes, Do 914's really stop! |
JmuRiz |
Jul 26 2023, 08:47 AM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
OK thanks guys, so now I know that a 914 does actually stop it's back to the drawing board with some of your suggestions. Cheers. Do not remove the proportioning valve. This was common back in the 80-90s and there are still some people that swear by it. I've seen the wreckage that results from the rears locking before the fronts first hand. When you get it dialed in, the 914 STOPS. Zach (IMG:style_emoticons/default/agree.gif) Yes, I made the mistake of removing the prop valve when I put boxster brakes on the front of mine. That ended up locking the right rear when doing emergency stop drills at an HPDE class. I'll send my old one out to PMB and have it rebuild and reinstall. The 19 is more pedal effort...it will lock up the front brakes full stock depending on the stickiness of the tires. |
Justinp71 |
Jul 26 2023, 09:06 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
To answer the title question, I put on wilwood front calipers on 911 3.5" struts and 914-6 rear calipers. With track pads I could go from 100-20 in what felt like 75' it was amazing!
But realistically everything in working order, fresh fluid and good pads they will stop well. I ran Porterfield RS-4 pads with a mild caliper upgrade for years. |
Root_Werks |
Jul 27 2023, 02:34 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
As others have said already, a stock 914-4 brake system is plenty of braking power. Something isn't right with your system.
Air in lines most likely Spongy rubber lines possible Rubber line internally failed not allowing pressure to caliper(s) Lots of things could impact braking performance. (IMG:style_emoticons/default/driving.gif) |
CCE |
Jul 27 2023, 10:34 PM
CCE Group: Members Posts: 326 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
Mine had the same feeling, solved after bleeding and some care to the system a second time, it changed a lot. It feels really agile now. (IMG:style_emoticons/default/headbang.gif)
In any case, I had to replace hoses, piston refurb, fluid, pads, rotor grinding, cleaning, bleeding, changing the main piston and such. (IMG:style_emoticons/default/lol-2.gif) Enjoy the ride |
jhynesrockmtn |
Jul 28 2023, 08:11 AM
Member Group: Members Posts: 420 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
If you don't know the history on your brakes, I'd suggest sending the calipers and pressure relief valve off to PMB for restoration, new MC and new soft lines. Blow out the hard lines or replace if they are rough. Then bleed properly and bed pads properly. They will stop just fine.
I bought a 1970 a few years ago that had sat for years. The rear soft lines were plugged/swollen shut. No fluid moving through them at all. The fronts barely worked. |
Chris H. |
Jul 28 2023, 08:43 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Also recommend the PMB soft lines. They are excellent quality.
Here's the link for 73-76. Not sure what year you have but they have both early and late Link: PMB Lines |
Porschef |
Jul 28 2023, 12:14 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Am I missing something??
Why 4 flex lines, I’m kinda sure there are only two up front... (IMG:style_emoticons/default/unsure.gif) |
jhynesrockmtn |
Jul 28 2023, 12:29 PM
Am I missing something?? Why 4 flex lines, I’m kinda sure there are only two up front... (IMG:style_emoticons/default/unsure.gif) You have two in the rear as well. They are kind of a pain to change out with the engine in the car but I've done it. My rears off my 70. |
Shivers |
Jul 28 2023, 12:30 PM
Senior Member Group: Members Posts: 2,414 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Am I missing something?? Why 4 flex lines, I’m kinda sure there are only two up front... (IMG:style_emoticons/default/unsure.gif) There are two that go from the chassis to the swing arms. From there it is hard lines |
Porschef |
Jul 28 2023, 01:05 PM
Jeez, I better up my game. (IMG:style_emoticons/default/sad.gif) I think they were changed not too much prior to when I got the car but who knows if that included the rears...
Thanks (IMG:style_emoticons/default/beerchug.gif) |
Porschef |
Jul 28 2023, 01:10 PM
You mean like here? (IMG:style_emoticons/default/blink.gif)
Biggles |
Jul 28 2023, 01:42 PM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
My brakes have been rubbish but i know the rears arent fully working so they are being restored. I'm also putting 5 simple grooves in all 4 discs to de-gas the pads which should also improve things.
930cabman |
Jul 28 2023, 01:51 PM
Advanced Member Group: Members Posts: 3,134 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Am I missing something?? Why 4 flex lines, I’m kinda sure there are only two up front... (IMG:style_emoticons/default/unsure.gif) You have two in the rear as well. They are kind of a pain to change out with the engine in the car but I've done it. My rears off my 70. After 50 years of hard life, these take a beating. The rears are a bit harder, but totally possible with the engine/trans in place |
emerygt350 |
Jul 28 2023, 05:49 PM
Advanced Member Group: Members Posts: 2,132 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Those rear lines are why I took it to my Porsche guy to do my PMB stainless braid. It took him an hour to do all four. It was money well spent.
jhynesrockmtn |
Jul 28 2023, 06:38 PM
Here is a pic of mine where it attaches to the chassis.
It is easier to cut the old line off as close to the "nut" as possible, then you can get a socket on it. |
Lo-Fi Version | Time is now: 4th June 2024 - 11:40 AM |
