Fule Pump or Fuel Regulator? |
chrispovoas |
Aug 7 2023, 12:03 AM
Member Group: Members Posts: 61 Joined: 8-April 23 From: New Zealand Member No.: 27,285 Region Association: Australia and New Zealand |
Hi guys, so on my journey to get the engine running an pulling correctly I have done the following;
1) Tracked down all of the air leaks so that the engne stalls if i cover up the main air intake on the air box 2) Refurbed all 4 injectors 3) Replaced the ignition leads, Rotor and distributor cap 4) Installed refurbed AA Valve 5) Checked the spark on all leads 6) Installed new plugs However, the engine still performs / runs like its on 3 cylinders... Once the injectors were done the engine was running sweet.. Parked the car for 2 weeks, engine back to running like a pig.. All 4 plugs were quite black (even after only running for about 3 miles in total since they were installed), which shows all 4 are getting fuel but running very rich. If the electrics are good, then it must be fuel? Perhaps the Pump or regulator?.. Anything i can check / test by myself? as my driveway is steep and the car doesnt have the power to get up it to take it to a mechanic Cheers Chris |
Lo-Fi Version | Time is now: 15th May 2024 - 01:17 PM |
