Ordering new Koni shocks- ride height question |
rjames |
Aug 17 2023, 03:19 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
About to order Koni struts and shocks (yellow) without the ground control option to replace the KYBs that are on the car now.
I'm also going to replace the sagging rear springs with Weltmeister 100 lb springs. They are ~15" long, which is shorter than stock, IIRC. Without a threaded collar, the Konis are limited in their height adjustment. Is it going to mess up the ride height in the back (too high or too low)? Anyone else running this setup? |
mlindner |
Aug 18 2023, 05:25 AM
Senior Member Group: Members Posts: 1,521 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Aug 18 2023, 07:31 AM
if you are seeking the perfect ride, given we have tweaked chassis from side to side...I would also suggest the adjustable spring perches.
This gets you into a much wider selection of spring rates, for pretty low cost per set. You can then, finally, properly corner balance the car... you can also set the ride height to exactly what you want. Rich |
Superhawk996 |
Aug 18 2023, 07:46 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I have a set of Konis with the standard adjustable perch via clips and 100 lb springs. No issues getting ride height where you want it for street use. I know there are many others on the site using the same Koni’s without issues. Surprised no one else has chimed in. If you search the site I’m sure you’ll turn up plenty of builds that used the Koni’s without the Ground Control threaded perches. |
Krieger |
Aug 18 2023, 07:49 AM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I would go with GroundControl adjustable Koni's, It's a great setup and priced well, with any spring rate you want. Best, Mark (IMG:style_emoticons/default/agree.gif) I wanted it a little lower with my 200# springs. I had a machinist cut two more groves into the shock body the same distance apart as Koni did. I am using the lowest grove I had cut. |
im not sure what you are intending to use the car for...but threaded perches really do help adjust for the 200lb driver when properly corner balancing a car.
If you have never driven a properly corner balanced car, properly aligned, you are certainly in for a treat when you finish. rich |
Lo-Fi Version | Time is now: 17th May 2024 - 06:18 PM |
